12-26-2017
20:55
18:54
12-26-2017
20:55
18:54
Can I get my battery life to display on my Fitbit?
12-27-2017 04:06
12-27-2017 04:06
Hi
From dear @MarreFitbit in this thread
'To charge your tracker:
While the tracker charges, you can tap it to check the battery level. A fully charged tracker shows a solid battery icon.
For help deciding when to charge your tracker:
Last but not least, when the battery is full you'll see it reflected on your Charge 2's display when charging it.
Hope this helps buddy!
12-27-2017 09:39
12-27-2017 09:39
@Amyb711 It's great to see that you've visited the Fitbit Community! Addtionally to what @SunsetRunner explained you can also add the battery icon to your tracker by going to the tracker's settings area and enabling this option. This way it will part of the menu so you can check the battery status any time you want.
Let me know how it goes!
06-05-2019 05:52
06-05-2019 05:52
The question was about battery life, not current charge level. How can I tell that my battery is near the end of life, not end of current charge?
10-24-2020 06:30
10-24-2020 06:30
TaylorDH0210:
I am wondering the same thing about battery health too! My Fitbit Blaze is about 3 and a half years old so I’m wondering if there’s anyway to tell how long the battery will hold up still. Any help on this, Fitbit?
11-21-2020 07:59
11-21-2020 07:59
I am wondering the same thing. My versa2 is only 2 months old and first it last 5-6 days for 100% to below 30%. Now past 2 weeks I have to charge every 3 days to get the same way. I contact Fitbit but they just said I maybe doing things that use battery more than before. All I do is check my sleep score and monitoring walking as a exercise. Is this mean my battery have problem?
So I like to see how is my battery life....how can I check? Is there any way to do?
11-21-2020 16:38
11-21-2020 16:38
I am also having to charge my Charge2 about every 1-1.5 days now, just this past week or so. Before that, it would stay charged almost a week. What kind of update has Fitbit given us that is sucking our batteries dry??
11-22-2020 06:19
11-22-2020 06:19
I contacted Fitbit using the chat, and they said that for my blaze, there is no option to check battery health....that's unfortunate. I'm guessing it's the same way with the other watches too.
