02-14-2020
02:04
10:23
02-14-2020
02:04
10:23
I accidentally deleted my charge 2 from my fit bit app. How can I reinstall the same device. I tried to install it again but it doesn't work. How can I get it back to my account?
02-14-2020 02:53
02-14-2020 02:53
The usual process is to go into the account section of the app by selecting your profile image at the top left of the main dashboard and then selecting "set up a device". Is this what you tried?
When you say install doesn't work, what problem did you have?
02-14-2020 14:06
02-14-2020 14:06
Best Answer02-14-2020 21:13
02-14-2020 21:13
Have you removed the Charge 2 from your phone? You say you removed the Charge 2 from your Fitbit account.
Does the charge 2 still show up in the Bluetooth setting? This will have to be removed.
Have you restarted both tracker and phone?
