12-26-2016
19:09
10:13
12-26-2016
19:09
10:13
How can you tell that your charge 2 is charging? How can you see that it is charged? Thank you
12-26-2016 19:28
12-26-2016 19:28
@Debra54, when you put it on the charger cable, it will display the battery icon on the screen showing the current level of the battery. Later, if you press & release the button on the side of the tracker (through the hole in the side of the charger adapter), it will again show the battery icon with the level of charge. If it is completely white, it is fully charged.
Note: If the Charge 2 has not been setup - successfully completed the setup procedure - you will not be able to see the battery icon when you put it on the charger. It must be setup before the display will work.
12-26-2016 19:28
12-26-2016 19:28
01-30-2019 17:42
01-30-2019 17:42
My mom eats fitbits it feels so funny
