01-28-2020
05:58
17:42
01-28-2020
05:58
17:42
how do I adjust the brightness on a charge 3. It seems to be very dim
11-06-2020 09:03
11-06-2020 09:03
It doesn't allow brightness to be adjusted.
Best Answer11-07-2020 08:03
11-07-2020 08:03
I have the same issue and going to by a charge 4.have you found that brightness is better compared to charge 3? Thanks
Best Answer09-12-2021 12:24
09-12-2021 12:24
I was able to brighten...very hard to see but thank you
Best Answer09-20-2021 06:33
09-20-2021 06:33
Update: when I contacted Fitbit, they sent me a new charge 3, no quibbles. Full marks for customer service I’d say!
Best Answer09-21-2021 06:52
05-27-2022 06:35
05-27-2022 06:35
I can'talso
have you manage sort it out
06-02-2022 15:04
06-02-2022 15:04
Yes why does Fitbit not offer a solution to this common problem.
06-02-2022 15:16
06-02-2022 15:16
08-17-2022 12:20
08-17-2022 12:20
I have had the same issue with charge 2. I went to the settings and clicked on brightness on and now I can not see the screen now to adjust or see anything. Please help me any suggestions.
Thank you
Best Answer08-21-2022 13:03
08-21-2022 13:03
Only if its under warranty. Other than that they will only send you a 35% discount on a new one. They are not a great company. I refuse to buy another product from them if they can’t even give us a proper fix for our current ones we own. That’s just a reward for exceptionally terrible customer service.
08-21-2022 13:12
08-21-2022 13:12
They didn’t ask me for any receipt or proof of purchase. I had said it was a Christmas present (which it was) and I’d had it for over a year. I received a new replacement without even asking. I have no complaints about customer service. However, I have recently noticed that this one is now having the same problem ie I can’t read the screen outside on a sunny day as the screen gets dims down. Annoying.
08-21-2022 23:16
08-21-2022 23:16
Best Answer08-21-2022 23:18
08-21-2022 23:18
Best Answer10-02-2022 17:54
10-02-2022 17:54
In the fitbit app? Cause it doesn't have brightness
Best Answer10-03-2022 08:41
10-03-2022 08:41
If I could read the display, I wouldn’t be looking it up on this forum
10-03-2022 10:21
10-03-2022 10:21
Best Answer10-03-2022 13:58
10-03-2022 13:58
TO CHANGE BRIGHTNESS , EVEN IF DIM !
Swipe the screen 4 times to the left .
You may see Settings at the top :
Press the Settings on the top half of the screen once. .
Then tap the screen at the top which changes to 3 modes of Brightness :
Normal ,
Auto
Dim
press the side button twice once you get the setting for you.
Best Answer10-04-2022 21:59
10-04-2022 21:59
A bright screen can suck a lot of energy out of a touchscreen Fitbit (such as a Versa, Charge 3, or Ionic). On your device's screen, swipe left until you find “Settings.” Select that. Scroll to “Brightness.” Tap that button to cycle through brightness levels.
Regards,
Will
01-07-2023 10:06
01-07-2023 10:06
This is a "chicken or the egg" problem. I know how to change the settings on the Charge 3. But how can I change the settings if the Charge 3 screen if it is too dim to see the screen? I've tried to resetting by changing the clock face and by connecting it to the charger for 8 seconds - no luck. I couldn't find a way to adjust the settings on the app. Is there way to change the settings on the app? If so, how?
Best Answer01-08-2023 01:47
01-08-2023 01:47
watch the video on YouTube for this issue .
when you are swiping sideways you need to count it carefully so you are on the correct selected menu ( even if it’s too dim to see ) , when you then tap the screen it only has 3 adjustments , Dim , Bright and Auto .
I’ve now got a Fitbit charge 5 but there seems to still be this issue with Fitbit Charge 3 .
