01-02-2020
00:09
15:40
01-02-2020
00:09
15:40
Hi
l would like to change from kilometres to miles on Fitbit charge 3
have googled it and said to go to advanced setting but can’t find it
hope someone can help
01-02-2020 05:31
01-02-2020 05:31
Hi there @Nannyopulos, welcome to the Community Forums. Thanks for doing some research about changing the Units on your Charge 3 prior to posting here. Nice way to go! 😉
You can click on the link provided by @SteveH and change the Units via the Fitbit online dashboard or you can follow the steps below for doing the change in the Fitbit app:
Let us know if you need further assistance. Happy stepping!
01-02-2020 01:27
01-02-2020 01:27
One way of doing this is via the web interface at https://www.fitbit.com/settings/profile
Change the length unit from "centimeters" to "feet/inches". Once the change has been saved you'll need to sync to update your fitbit.
01-02-2020 05:31
01-02-2020 05:31
01-03-2020 00:45
01-03-2020 00:45
04-09-2020 11:03
04-09-2020 11:03
Was looking for an option in (advanced settings - units) for an option to change from miles to kilometres. After an hour or so of frustration I came across your reply. Changed from feet/inches to centimetres and hey presto, problem solved. Thank you 😊
