03-12-2019
11:43
11:22
03-12-2019
11:43
11:22
Hi, I have a new Charge 3 but didn't like the band that came with it. I purchased one from Amazon that looks more like a regular watch band. Are these hard to trade out? I don't want to ruin my Fitbit. Thanks!
03-12-2019 12:36
03-12-2019 12:36
Make sure the band will fit your exact model. I've changed from the Charge 2 to the Charge 3 and the bands do not interchange.
@nanamorgan1 wrote:Hi, I have a new Charge 3 but didn't like the band that came with it. I purchased one from Amazon that looks more like a regular watch band. Are these hard to trade out? I don't want to ruin my Fitbit. Thanks!
Best Answer03-12-2019 12:45 - edited 09-25-2020 07:09
Charge 3 bands are easy to switch.
See How do I change the wristband on my Fitbit device?
That link has big diagrams. After switching, always make sure the new one is secure before wearing it outside.
03-13-2019
08:17
11:41
03-13-2019
08:17
11:41
A warm welcome to the Community @nanamorgan1, @kathalida and @JohnnyRow thanks for the input.
I was able to see here that our friends answered your question about changing your tracker's wristbands.
If these answers were the ones you were looking for, I recommend marking the answers given as a solution. By doing this, other users with the same inquiry will be able to find a faster response.
Now if your inquiry/issue wasn’t resolved, let me know and I will be glad to help you out. ![]()
03-13-2019 10:44
03-13-2019 10:44
03-14-2019
04:19
11:40
03-14-2019
04:19
11:40
Those are great news @nanamorgan1. I am glad to hear that everything is working for you. If there is anything else we can help you with, do not hesitate to post it.
Keep the stepping up! ![]()
Best Answer03-14-2019 20:14
03-14-2019 20:14
I purchased a new band for my Charge 3 that looks like a metal watch band. Thanks to a reply from my post, I was able to attach my Fitbit to the new band with no problem at all. However, now one end of the Fitbit will not stay attached to the band. I hear the "pop" that lets me know everything is attached but all of a sudden one side comes loose from the latch. The three times it has done this it's fallen on carpet but I'm concerned that it will fall off on concrete or a hard surface and break. Any ideas for how I can get this to stay attached to the band? I actually thought about using super glue but don't want to ruin it completely. Any suggestions would be really appreciated. Thanks.
Best Answer03-15-2019 06:18
03-15-2019 06:18
03-15-2019 07:15
03-15-2019 07:15
Best Answer02-06-2020 18:02
02-06-2020 18:02
cant get the band to stay on. help
Best Answer05-17-2020 04:06
05-17-2020 04:06
I have a charge 3 & wish to change strap for a rose gold mesh strap . I can only see on Fitbit website an inspire rose gold strap . Will that fit the charge 3 ?
Best Answer09-10-2020 13:24
09-10-2020 13:24
I have tried to replace my Charge 3 band after the original broke. The replacement band kept on falling off. Now the replacement has broken...and i can't get the bottom band to attach. Do i really need to get a whole new fitbit to address this 'band' issue? Makes me think an applewatch might be the way to go!! grrr. Any suggestions?
Best Answer10-21-2020 06:12
10-21-2020 06:12
My band broke last night, and when taking the old piece off to tape it up (while I wait for my new band), I had trouble getting the band to stay attached to the tracker. I removed both bands that connect to the tracker. One side is clean as a whistle; the other side is extremely dirty. In fact, it looks like the dirt build-up has affected the latch from moving at all. I cleaned the dirt off with a paper-clip and was able to pry the latch in the up/locked position. The watch went back together (for now!) and seems to be holding fine.
Dear Fitbit: that latch design is terrible. If me working in the yard, playing golf, exercising, etc. corrupts the latch that holds the watch together, you need a new design. I will probably get 1 band replacement out of this and then have to throw the watch away. Maybe you're designing your products to break, instead of trying to grow your happy, satisfied customers?
