How do I change my food log from kJ back to calories
Hi guys!
Since an update on my fit bit app yesterday my food log has changed from calories to kj just wondering if anyone knows how to change it back. I have a charge 2.
thanks heaps 😊
2 REPLIES 2
You should be able to do this via the iOS app.
Go into the account section of the app (select your profile at the top left if you are on the new design; select the "ID card" icon at the top right if you are on the old design). Then scroll down and select "Advanced settings". On the next screen select "units" and you should then be able to choose between kilocalories and kilojoules - I say "should" as I'm on android and don't yet have this option so can't test it.
Thank you so much for that! I just tried it and it has worked. Thanks for your help 😊
Sent from my iPhone
