08-01-2023
01:05
09:22
08-01-2023
01:05
09:22
How to change exercise choice on Fitbit charge 4
08-01-2023 02:26
08-01-2023 02:26
Hi, @Bernied66 , assuming that you mean which Exercise Shortcuts are loaded onto your Fitbit:
Go to your app and from the opening screen click on the person photo/icon. On the next screen click on your Charge 4 picture. Then scroll down until you find Exercise Shortcuts. Click on that. If all shortcuts are in use you will need to delete one or more before you can add any. You can also drag and drop to reorder the way they are shown on your Fitbit (putting ones you use most at the top).
Be sure to sync your Charge 4 so that any changes you make in the app are reflected on your Fitbit device.
When you are ready to start and exercise swipe until you come to the app and then swipe and tap to begin your chosen activity.
For more information about how to track your exercise activities using your Fitbit please see this help article .
I hope this helps. Welcome to the Community Forums!
08-01-2023 02:26
08-01-2023 02:26
