08-09-2021
13:07
05:26
08-09-2021
13:07
05:26
How do I change the time on my charge 2
08-10-2021 00:01
08-10-2021 00:01
You can't manually set the time, but it should reset itself whenever it syncs to your phone based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the time zone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
08-10-2021 00:01
08-10-2021 00:01
11-08-2021 12:01
11-08-2021 12:01
I live in Massachusetts - it had me in San Juan lol. Thanks!
Best Answer03-01-2022 06:50
03-01-2022 06:50
I set it on east time and still not changing on watch
08:26
09:20
03-01-2022
08:26
09:20
Welcome to the Fitbit Community, @hawthorne1950. Thank you for letting us know that you set your watch on east time and it´s still not changing on it.
Sync your Fitbit device to see the correct time. For more information, see How do Fitbit devices sync their data?
Since you changed time zones and the time on your device is still incorrect after syncing, make sure the time zone setting is correct:
