How do I change the time on my Charge 3?
ANSWERED
The time showing on my clock is 1 hour behind the actual time how do I change the time to automatically pick up the correct time.  DST/Standard time zone?
1 BEST ANSWER
Accepted Solutions
Welcome to the forums!
On the computer Dashboard go to settings then scroll down to timezone and make sure it is correct.
If you make a change it will need to sync before it takes place.
Hope to see you around!
Community Council Member
Wendy | CA | Moto G6 Android
3 REPLIES 3
What if I don't have access to a computer. I'm camping right now.
Hello everyone. @Mtalvar Welcome to the community forums!
Thank you for the information. If you don't have a computer, take into consideration that you can also adjust or change the time zone using an Android or iOS device through the Fitbit App. For this, please check the following help article: How do I change the time on my Fitbit device?
Hope this helps.
Wilson M. | Community Moderator, Fitbit.
