12-26-2019
19:46
20:25
12-26-2019
19:46
20:25
I want to switch from my dominant wrist to my non-dominant wrist but can not figure out how to do it on a Charge 3. Does anyone know how?
12-27-2019 04:54 - edited 04-18-2024 09:43
Hi there @WendyB, welcome to the Community Forums.
As my friend @WendyB said, you can follow those instructions in order to change the wrist setting on your computer. However, if you prefer to change it directly from your Fitbit app, follow the steps below:
Let us know if you need further assistance.
12-26-2019 20:54
12-26-2019 20:54
Welcome to the forums!
On the computer dashboard Go to Settings and scroll down to wrist. Open it up and choose the one you want
It will need to sync before it takes place
Wendy | CA | Moto G6 Android
05-18-2020 10:11
05-18-2020 10:11
I cannot find where it says Wrist to be able to change dominant handedness.
02-09-2021 16:49
02-09-2021 16:49
Tapping the today tab on the fitbit only brings up steps and the rest of the info for today. What do you mean by "device image"? I'm not seeing this anywhere.
10-16-2021 13:57
10-16-2021 13:57
Sorry, no Wrist listed
10-17-2021
15:01
09:41
10-17-2021
15:01
09:41
Hi everyone. Thanks for stopping by @Phil456.
Sorry to hear that the wrist option is not listed. I'd suggest making sure of the following:
Hope this helps.
12-02-2021 12:03
12-02-2021 12:03
That worked, Thank you Cindy
01-05-2023 18:11
01-05-2023 18:11
Is there a way to change settings so it knows if you are left handed? My non-dominant is fitbits dominant
