04-28-2019
12:33
11:08
04-28-2019
12:33
11:08
I have a Charge 3. I've looked everywhere on the app and can't find out how I can edit my daily step goal from 6000 to 7500 steps per day. Can anyone help with this?
04-29-2019 04:57
04-29-2019 04:57
Hello there @CoffeeMugs4Me, it's nice to see a new member around! To change your daily step goal, follow the steps below:
Note that you can also set and manage your goals using the fitbit.com dashboard, but the personalized guidance is only available in the Fitbit apps.
Hope this helps, let me know if you need further assistance.
04-29-2019 04:57
04-29-2019 04:57
06-06-2019 07:16 - edited 06-06-2019 08:28
I finally figured it out..select where your steps show on main page and go to settings icon upper right corner...select Steps and change number..
06-06-2019 07:30 - edited 04-29-2024 05:45
Welcome to the Community Forums @Felix55!
Are you getting any error when trying to update your goals? Are you using a computer of the Fitbit app? I'd appreciate if you can give me more details of what you're experience so I can help you in a better way.
In the meantime, I'd recommend taking a look at the following help articles:
06-06-2019 08:30
06-06-2019 08:30
I was able to get it changed, I left info on this page...thank you!
Best Answer06-06-2019 08:44 - edited 03-28-2024 05:30
Hi @Felix55! I'm happy to hear you were able to change it. ![]()
I would like to invite you to visit our Discussions board where you will find great tips and encouragement from other members and if there's anything else I can do for you, please keep me posted.
I hope you have great day!
06-06-2019 08:49
06-06-2019 08:49
I was trying on my ipad and iphone and finally got it changed on my iphone on the fitbit app by selecting the circle where it shows current steps and then selected the setting icon in upper right corner and changed the number of steps..let me know if I made that confusing...lol
Best Answer06-06-2019 11:24
06-06-2019 11:24
Hi there @Felix55! You made it right. ![]()
12-05-2019 18:14
12-05-2019 18:14
I can't find the goals on the Windows 10 version of this application. Is it different that what you have described in other messages in replies to editing daily step goals.
Best Answer01-26-2020 07:34
01-26-2020 07:34
This is by far the best answer. It worked! Thanks.
01-26-2020 11:10
01-26-2020 11:10
Awesome, glad it helped!!
Best Answer04-04-2020 07:16 - edited 04-04-2020 07:24
4/4/2020. This does not work for me. I have firmware # 28.2001.63.5.
By tapping my numbers for the day, I can now see that my goal is set where I want it. Must have carried over from the sync.
That brings my next question: Is there anyway to get back the 7 or 8 days of data while I was waiting for my replacement fitbit to be delivered. I wore it continuosly. In fact when I set up the new fitbit charge 3, I had around 6700 steps on it in the middle of the afternoon. but those steps, nor the ones in the preceding days to March 25, 2020 synced in.
Best Answer03-02-2021 12:27
03-02-2021 12:27
Thank you 👍
Best Answer01-04-2022 07:25
01-04-2022 07:25
Hi MarreFitbit,
I have a Charge 3, and the Daily step goal is set to 6000. I want to change it, and have found the place to do it, but i doesn’t save the new number, it goes back to 6000 - what can I do?
Best regards
