05-28-2020
04:16
09:30
05-28-2020
04:16
09:30
How do i get sleep info to display again?
06-02-2020
09:34
05:53
06-02-2020
09:34
05:53
@Irochtx It's great to see that you've visited the Fitbit Community!
Let me help you with your sleep information. On the Fitbit app go to the Discovery tab then tap Health and Fitness Stats where you can add the sleep. If the issue is that your tracker isn't recording your actual sleep then note that your device will start recording sleep after it detects an hour of inactivity. If you have a light sleep or move too much then this may difficult your sleep detection. Additionally you can try wearing your device on your non dominant hand to decrease the amount of movement it is subjected to. Finally you can restart your device. You can also manually log your sleep time. You can read more about sleep detection here.
Let me know how it goes.
