01-24-2017
01:42
10:13
01-24-2017
01:42
10:13
Hi novice user here. How I do get my steps to display all the time on my wrist strap? I only see them on my dashboard on the app, but not on my wrist! Thanks!
01-24-2017 02:38
01-24-2017 02:38
It should be on the first screen. There are 2 feet and the steps underneath.
If you dont see them them tap the screen until they come up
Might want to read the manual . It can help you understand your unit
https://staticcs.fitbit.com/content/assets/help/manuals/manual_charge_2_en_US.pdf
Wendy | CA | Moto G6 Android
01-24-2017 06:08
01-24-2017 06:08
One of the clock face options under your settings will put your steps as well as a clock and your heart rate right on your 1st screen of your fitbit. Check out the diff clock face options
Best Answer01-24-2017 16:51
01-24-2017 16:51
01-24-2017 23:44
01-24-2017 23:44
On the web dashboard, click the settings gear - charge 2 - Clock faces
Best Answer04-21-2020 14:43
04-21-2020 14:43
Thanks that helped. Unfortunately the clock type change reset all the steps and floors I climbed to zero!
Best Answer04-21-2020 14:50
04-21-2020 14:50
Hello ljweez:
Thx for your instructions that worked for me using a Charge 3 but it was a little tricky. One has to touch the top left of the app screen to get into the menu for the clock faces.
Unfortunately the clock face change reset all my steps to zero as it did for the flights of steps climbed!
A bug that they need to fix! 🤓
