11-25-2018
18:51
14:34
11-25-2018
18:51
14:34
How do I get the weather to show on my charge 3? I added a city in the settings but it's not showing up.
Thanks!
11-25-2018 19:21
11-25-2018 19:21
On the home screen, swipe left three screens and you should see the weather app. Tap that and the weather info for the city should show up.
Warren | Cincinnati, OH
Versa Lite, Ionic, Charge3, Inspire HR, Blaze(retired), Alta( retired),- Pixel 3
11-25-2018 19:21
11-25-2018 19:21
11-25-2018 19:31
11-25-2018 19:31
Gosh, so simple. Thank you! 😀
12-26-2018 15:52
12-26-2018 15:52
My weather not working in UK why says no weather data available
Best Answer12-26-2018 20:00
12-26-2018 20:00
Same in Dallas. Anyone have an idea? None of the Fitbit “fixes” worked.
01-02-2019 17:54
01-02-2019 17:54
Go to your Fitbit app on your device, and swipe left until you see “Apps” then click on the weather and current location will be there. You can add one more city. If it doesn’t work, once you’ve set the location try re-syncing your Fitbit App with your watch. Hope this helps.
01-02-2019 22:55
01-02-2019 22:55
Hi
thanks I followed your instructions and this worked when I went into my app itself and added my city didn’t realise I had to do this thank you 👍🏻👍🏻
01-03-2019 08:59
01-03-2019 08:59
In my Fitbit charge 3, the city near me is NYC it’s okey But where is the Weather??
Best Answer01-10-2019 22:10
01-10-2019 22:10
I tried all of the above and I still cannot get the weather to come up on my Charge 3. I double checked my Settings on my IPhone to make sure my location was on and my city is added to the Fit Bit weather app. Still nothing.
01-11-2019 07:53 - last edited on 10-27-2019 18:56 by LiliyaFitbit
Yes I got the Weather!! Thanks
Best regards
Best Answer07-27-2019 05:23
07-27-2019 05:23
To get weather, make sure location services is turned on in your phone fir the Fitbit app, set to always..you swipe left on the Fitbit, in the Fitbit app you can add other cities besides current
07-27-2019 05:24
07-27-2019 05:24
Make sure location services is turned on for the Fitbit app in your phone
Best Answer08-21-2019 03:17
08-21-2019 03:17
thanks so much, was so frustrated trying to sort this out before!
Best Answer01-12-2020 12:17
01-12-2020 12:17
Thanks, it worked. Seems simple but can be tough for an old school manual guy.
Best Answer06-11-2020 06:48
06-11-2020 06:48
Yeahhhh thanks , this worked , only just got mine , but couldn’t sync the weather , but after your suggestion it’s working , thank you 👍🏻👍🏻
