01-03-2020
12:56
15:39
01-03-2020
12:56
15:39
Hi, I would like to know if it’s possible to get notifications from WhatsApp, messenger and text at the same time in charge 3 for androids?
when I tried it made me select one of the apps and I would like to get notifications from the 3.
thanks a lot!
01-04-2020 09:53
01-04-2020 09:53
Hi there @Bdhruve, welcome to the Community Forums. Thanks for the details provided, I'll be glad to help you.
While reading your post I was wondering if the mobile device you're syncing with is included in our list of supported devices? You can see the list at: Which phones and tablets can I use with my Fitbit watch or tracker?
Please keep in mind that when a device is not supported we cannot guarantee its functionality with the Fitbit app. It might work at a certain time and then it can stop working out of nowhere after an update. This is because the app is not optimized to that device and any change could impact the performance.
In regards to your question, you can receive notifications from the 3 apps you mentioned. But, since you're setting up notifications, you'll need to receive a message from the app desired in order for your app to show it as option in your Fitbit notification's section. For example, tell someone to send a WhatsApp, then check your Fitbit app and you'll see that WhatsApp is already an option to be selected.
I'd recommend following the steps in the article: How do I get notifications from my phone on my Fitbit device?
I hope this clarifies your question and helps you to set up your notifications.
