05-04-2016
01:18
20:15
05-04-2016
01:18
20:15
My fit died about 2 months ago and I have now received a replacement one
How do I delete / remove the old Charge HR from my e-mail address, so I can set up the new one?
thanks
05-04-2016 01:44
05-04-2016 01:44
I've tried to set it up and it says are you replacing the existing Charge HR (words to that effect) and I am but when I press the button on the side I get the ! Exclamation Mark followed by the charging sign then it turns off... it briefly came up on my mackbook pro that my tracker had been found and to enter the 4 digit number that came up, but then it said there was an error / problem and I had to start again.
but when I press the button on the side I get the ! Exclamation Mark followed by the charging sign then it turns off... no numbers come up and my macbook pro says it can't find my tracker.
I have put the tracker on the recharge and will try again later, but it is not off to a good start with my replacement charge HR!
Best Answer05-05-2016 08:17
05-05-2016 08:17
It's great to see you around @NZNick. I recommend Restarting your Charge HR and after the restart process, follow the setup procedure from a Computer. If these steps don't work, feel free to contact our Support Team. For a faster response you can contact them via phone or chat.
Let me know the outcome.
05-06-2019 07:40
05-06-2019 07:40
How do I replace Fitbit.
Best Answer05-08-2019 13:11
05-08-2019 13:11
@kfredx Replace it like stated above? Read the post above yours there are links.
Or replace a bad device? Contact support. Use help link at top of forum.
Wendy | CA | Moto G6 Android
