01-26-2016
20:00
20:15
01-26-2016
20:00
20:15
Good evening,
Before I leap into my issue, I would like to say that my FitBit has been one of the best purchases I have made in recent memory. I love this product so much that I ordered one for my mother and one for my father (who are technilogically impaired for the most part), and they were thrilled to have one.
That being said, I have run into problems with my personal FitBit Charge HR. The band is detaching at the screen display (yellow), and there are these rogue "bubbles" that are gradually becoming worse (red).
Is there anything that can be done? I'm really discouraged by this because I've only had the product for four (4) months. I followed the proper care guide, but that only went so far. As I stated above, I love my FitBit and I don't want to consider going with another brand. The band tearing away and the floating air pockets are a blemish on an outstanding product -- and no one wants to wear a blemished product. I've refrained from showing my FitBit to others because I believe this product is far above what it currently presents itself as.
Any help concerning this manner would be greatly appreciated. Thank you.
- Kevin
01-26-2016 20:50
01-26-2016 20:50
I have the same issue with the air bubbles. looks like it is growing a tumor. Any help would be great.
01-26-2016 21:12
01-26-2016 21:12
I would contact FitBit and have it replaced under warrenty. It looks like a factory defect.
01-27-2016 08:03
01-27-2016 08:03
This happened on my first Fitbit (purchased in July 2015). Customer service replaced very quickly after verifying my purchase and receiving pictures that I sent (October 2015). Unfortunately, I just submitted another request because it is happeneing again. While I really appreciate the quick and friendly support, has anyone figured out why this happens? I don't submerge the device in water. I don't even wear it to Bikram yoga because its so steamy. I take care of it according to the instructions. For the price and the purpose, I'd expect it to be more durable. Has anyone found a way to prevent this?
Thanks!!
01-27-2016 08:09
01-27-2016 08:09
@KevinK26 As others have mentioned, your Fitbit is covered with a one year warranty (assuming you purchased it from an approved retailer). Customer Service will be able to help get the replacement process going for you.
Best Answer01-27-2016 09:53
01-27-2016 09:53
Best Answer04-25-2016 13:21
04-25-2016 13:21
I have the same issue. I got mine December 2015, and by April 2016, it was delaminating at the screen. I took very good care of it. In fact, I was a couch potato for the first 3 months of the year, and didn't even wear it for over a month of that time.
Upon reporting it, Fitbit promptly replaced it under warranty, but I'm afraid its going to happen again in 4 months, because I'm wearing it now every day and I am much more active now that the weather is warm. There doesn't seem to be anything that can be done once it starts to delaminate.
Best Answer04-25-2016 16:26
04-25-2016 16:26
04-29-2016 23:33
04-29-2016 23:33
04-30-2016 06:25
04-30-2016 06:25
05-25-2016 19:58
05-25-2016 19:58
I love my Charge HR is great. The customer services was great. They sent me another Charge HR. However this is my third one with the same problem. The screen button is falling apart. I asked if this is. No a factory default. No response other than send a new one. What I want is a good product when I pay the price for it.
05-25-2016 20:09
05-25-2016 20:09
@golfprincess wrote:I love my Charge HR is great. The customer services was great. They sent me another Charge HR. However this is my third one with the same problem. The screen button is falling apart. I asked if this is. No a factory default. No response other than send a new one. What I want is a good product when I pay the price for it.
Yep, great customer service until you hit that 365 days.... Then, the great customer service is over and you are left with whatever you got last, knowing the same thing is going to happen to it with nothing to fall back on as far as a replacement for what is obviously a factory defect. These things must be extremely cheap to produce so they can just keep sending out new/"refurbished" ones until the warranty is over. Some folks have received 5-6 replacements. You think fb would be doing that if they cost ANYwhere near the retail price????
05-25-2016 20:54
05-25-2016 20:54
Best Answer05-25-2016 21:12 - edited 05-25-2016 21:13
@Grrr8scott wrote:
Will the bubbling cause any problems long term? Mine is doing it, too. My year is up in December, so I'd like to wait a bit before I call customer service.
You should call now and get a new one. Keep getting new ones as long as you have the warranty and they go bad. Make them honor that warranty. For some reason, at some times, they make you return the bad one to get a new one. At other times, they just send you a new one. So, you may end up with more than one tracker. I actually had 3 by the time my warranty ran out. One has now died completely - electronics failure. But, I have 2 with bad bands that I am limping along with. I have also removed the good band from the failed tracker and have put it aside in case the glue fixes eventually fail and I need a 'new' band. Obviously this is only for those who are beyond the warranty period.......
But, if push comes to shove and the warranty runs out on you, some super glue should keep it in tact for awhile.
Best Answer05-25-2016 21:17
05-25-2016 21:17
Best Answer05-30-2016 15:49
05-30-2016 15:49
i've had mine for 6 months and the same issues with my charge hr band defect.
Best Answer08-22-2016 07:41
08-22-2016 07:41
I called today because my FItbit Charge HR is stuck on the update screen. I also have the issue where the casing falls off. I was told that these are known issues but since I am outside of the warrenty period the best they could do is a 25% promo code..... OK, so this is my 3rd Fitbit.... i've had issues with all 3 after the warrenty peroid. None of which were replaced and I stupidly kept upgrading. If this is a known issue then stand by your product and replace it or recall it! These are expensive toys to keep buying every 365 days! Shame on you Fitbit
08-22-2016 15:56
08-22-2016 15:56
08-22-2016 16:18
08-22-2016 16:18
Best Answer08-23-2016 07:55
08-23-2016 07:55
Thanks for this information @Jimmy_c. Rather spend the 10 bucks in order to get a replacement since they seem to always break just after warrenty is up.
