05-02-2019
18:43
11:08
05-02-2019
18:43
11:08
My Fitbit Pay has stopped working because I forgot my 4 digit PIN. I'm trying to find PIN reset on my dashboard but I can't locate that function in my mobile app dashboard.
How do I reset my PIN with a factory Reset? Can't find this topic in any threads. Please help!!
Thanks
Yawen
05-03-2019 05:04 - edited 03-17-2024 05:54
Hello there @Sassygirl.s, it's nice to see you here! Thanks for already trying to reset your PIN on your Dashboard and on your Fitbit mobile app. Nice way to go!
To unlock your device with your phone:
Note that after you reset your PIN code, you must add your cards to Fitbit Pay as if you were setting it up for the first time.
If you need further help, I'd recommend taking a look at the help articles: How do I use the device lock on my Fitbit device? and What should I know about Fitbit Pay?
Best Answer08-06-2019 10:00
08-06-2019 10:00
Hello. I also forgot my password and can’t do the suggestion because when I go to “Device Lock” it asks to enter the 4 digit PIN that I forgot. So there is no possibility to change or reset it.
08-16-2019 03:00
08-16-2019 03:00
On point 2
When you select device lock, it does not give options, it asks for your pin code before you can proceed.
I dont even remember setting this up and none of my usual pin numbers work, is there a way to reset the pin?
07-06-2020 17:39
07-06-2020 17:39
Just had to do this, you have to continually get the passcode wrong until you run out of attempts. Doing this wipes you fitbit wallet so youll have to set it all up again but will allow you to make a new code.
I know this info is probably way to late to be helpful to you but hopefully putting it here will make it easier to find for the next person that has to do it
01-02-2021 10:40
01-02-2021 10:40
It's definitely helpful for me!! I have to do it right now!! Thank you!! ✌️
Best Answer09-17-2021 02:06
09-17-2021 02:06
It took me a lot of wrong guesses to figure this out, but the pin it's asking for is your phone pin. Enter that, and you'll see the option to reset your fitbit pin.
Best Answer03-07-2022 22:41
03-07-2022 22:41
Thanks I will try 3
Best Answer03-07-2022 22:42
03-07-2022 22:42
No that didn't work for me
Best Answer03-07-2022 22:44
03-07-2022 22:44
No didn't work
Best Answer10-12-2022 21:14
10-12-2022 21:14
I was just running into same issue. I logged in via website. I went into my account—-> settings—->clicked on device icon then you should see “deactivate Fitbit pay”. Then I went back into the app went into account ——>Device icon—->device lock and was given option to change pin
Best Answer03-30-2023 15:33
03-30-2023 15:33
I think that's because you set it as your phone pin. When it prompts you for the pin, it even says "Your [FITBIT_MODEL] already has a PIN"
Best Answer04-11-2023 22:25
04-11-2023 22:25
In the Fitbit app, tap the Today tab. your profile picture. your device image.
Tap Device Lock.
Find the option to change your PIN code.
Hope this helps,
James (Cloud Desktop hosting expert)
