12-09-2018 21:49 - last edited on 11-17-2020 14:34 by MatthewFitbit
Hello, I can't restart my Charge 3 with none of your methods on the page. How can I do it? I need yo update it.
01-27-2019 12:20
01-27-2019 12:20
This worked for me. Thanks
01-31-2019 09:43
01-31-2019 09:43
Same issue for me, changed clock face - thanks 🙂
01-31-2019 17:22
01-31-2019 17:22
Thank you for this! Changing clock face worked for me as well
02-07-2019 05:55
02-07-2019 05:55
This worked for me. Thanks. I charged my Charge 3 about a week ago, and ever since then the face has been blank. Logging into the app and changing the face worked.
02-07-2019 19:58
02-07-2019 19:58
Thank you for adding that you need to hold the button for 8 seconds to restart the Charge 3.
I am now waiting for it to re-charge, as it went flat from being in the 001 fault mode all morning.
02-12-2019 13:07
02-12-2019 13:07
this was an easy way to reboot my charge 3, but it still didn't correct the issue with displaying the weight. The right weight shows online and on my app, but not on my charge 3
02-18-2019 12:50 - edited 02-18-2019 12:51
Had the same issue and changing the face of the clock worked for me also! Go figure! Thanks for the suggestion.
02-26-2019 05:28
02-26-2019 05:28
Hi there,
My tracker stopped working tonight while I was sleeping. I plugged it to the computer and hold the button for 8 secs. A white line appeared in the middle of the display but nothing else happens. Now the button is not working either.
Any thoughts?
03-06-2019 15:01
03-06-2019 15:01
Thank you!
The reboot with charger worked.
03-10-2019 11:52
03-10-2019 11:52
Not working just vibrating not showing that it is charging either
03-14-2019 06:55
03-14-2019 06:55
Thank you Mike. Changing the clock fixed the issue.
03-16-2019 12:45
03-16-2019 12:45
Thanks very much! It worked! That was easy!!
03-19-2019 20:42
03-19-2019 20:42
I did the whole plug in and push the button for 8 secs but it still won't restart. I have a notification stuck on the screen from a long time ago that won't go away. Any other ideas to fix it?
03-24-2019 08:20
03-24-2019 08:20
My Fitbit screen went out yesterday, I went to check the time and clicked the button on the side of the watch. It vibrated still but the screen did not come on. I thought maybe it had died, although, I knew my battery was at 50%. I charged it when I got home but still nothing. I tried restarting it multiple times while on the charger and the only thing that comes on the screen is the smiley face. I take the watch off the charger and the screen is black again. I opened the app to see if maybe the watch needed to be updated and when I pull down on the page for the app to sync with my watch it's continuously looking for my watch and can't connect. SO then I open my Apple settings on my phone and the bluetooth is disconnected. Tried reconnecting multiple times and it would not work. I'm not sure why this is happening considering this watch is only 3 months old but I am very disappointed and super frustrated.
03-24-2019 08:42
03-24-2019 08:42
06-25-2019 11:23
06-25-2019 11:23
WHERE IS THE BUTTON? FFS this is a simple question. I've spent thirty minutes looking up instructions which all say "press the button" but they don't explain where the effing button is. Who writes these manuals?
06-25-2019 12:59
06-25-2019 12:59
06-25-2019 13:28
06-25-2019 13:28
06-27-2019 07:18
06-27-2019 07:18
07-06-2019 17:29
07-06-2019 17:29
Hi
I am also having a problem with my Charge 3 not starting. I went through all the steps you mentioned, got the vibration and the smiley face but still a blank black screen. I have had this problem before but have always managed to get it going. Not this time!
And also, my iPhone cannot find the Charge 3 with the Bluetooth connection. I have tried deleting the App, reinstalling the app, turning Bluetooth off and then back on, but still nothing.
Help please! It is only about 6 months old.
