12-09-2018
21:49
14:34
12-09-2018
21:49
14:34
Hello, I can't restart my Charge 3 with none of your methods on the page. How can I do it? I need yo update it.
05-14-2020 14:55
05-14-2020 14:55
Thats really good and worked a treat.
Frequently when a computer has an issue you are told to reboot it
seems to work in this case too.
Best Answer05-20-2020 04:44
05-20-2020 04:44
Tried the clock face change and it restart the syncing process but the clock won’t reset (the reason I needed help). It’s stuck on Pacific time since I just returned from a trip there. Anyone got a clue on getting my clock sync with the proper time zone?
Best Answer08-04-2020 06:57
08-04-2020 06:57
Thank you SO so much! I just did what you suggested with changing the clock face and it worked! Thank you so much for suggesting it!
Best Answer10-02-2020 17:02
10-02-2020 17:02
The restart Charge 3 link is to an access-controlled page - not helpful
Best Answer11-12-2020 05:57
11-12-2020 05:57
Thanks, that worked.
08-22-2021
19:24
04:31
WilsonFitbit
08-22-2021
19:24
04:31
WilsonFitbit
On Fitbit Charge 3 and Fitbit Charge 4, you can restart your tracker from your wrist. Open the Settings app
and tap About
Reboot Device.
If your Charge series tracker is unresponsive: .
Moderator edit: removed personal information/format
Best Answer08-22-2021 20:56
08-22-2021 20:56
Hi @LeVuong you shouldn't be telling people to contact you if they are still having issues - you are not a Fitbit employee and this is not how Fitbit conducts things.
04:34
07:36
08-23-2021
04:34
07:36
Hello everyone. @LeVuong Nice to see you around. @Odyssey13 It's great to see you around and thanks for the input.
@LeVuong I also appreciate your support and thanks for sharing the tips to restart a Charge 3 and a Charge 4 device. At this time, I'd like to let you know that if the suggested tips shared in a thread don't work, the best recommendation is to contact our Support Team for assistance. The only way to get in touch with our Support Team is by clicking in this link.
11-07-2021 13:40
11-07-2021 13:40
My charge 3 just keeps vibrating as it goes through several windows. Restarted it without any change in behavior. Help
Best Answer12-12-2022 06:32
12-12-2022 06:32
I connected my fitbit and pressed the button for 8 seconds. I only get the fitbit logo (dots) and then the screen turns off. I press the button and goes back to the logo. What else can I do?
