02-05-2021
13:36
09:40
WilsonFitbit
02-05-2021
13:36
09:40
WilsonFitbit
How can I use the calendar on the charge 3?
02-05-2021 16:23
02-05-2021 16:23
To set it up, make sure your calendar is available on the phone you're connecting your Fitbit to. After that, go onto the app (make sure your Fitbit is synced), then click on your profile, click on your Fitbit device, click on apps, then click on agenda. From there you want to make sure you allow everything in the permissions menu and make sure the setting are the way you like them to be in the settings menu. It should then be set up after you sync your device again. Hope this helps!
P.S. you can also access the setting for other apps in the same apps tab.
Best Answer02-11-2021 09:38
02-11-2021 09:38
Hello @_.seve._, welcome to the community forums! @Mrb731 it's great to see you here in the forums and thanks for your great input!
Adding to what @Mrb731 mentioned, you can get more information about how to setup calendar notifications here.
How do I get notifications from my phone on my Fitbit device?
I'll be around.
