How do I setup my agenda on Charge 4?
Why is my Charge 4 not compatible with the Agenda App. You advertise that it is? Feeling conned!
10 REPLIES 10
It's great to see you here, @Traceybe.
To set up the Agenda app:
  1. In the Fitbit app on your phone, tap the Today tab
    > your profile picture > your device image > Apps.
  2. Tap the gear icon
    next to Agenda. You may need to swipe up to find the app. You’ll see all calendars linked to the default calendar app on your phone.
  3. Adjust the settings to choose which calendars to show on your device, the color for events linked to each calendar, and whether you want to see blocks of free time.
  4. Sync your device to see today’s and tomorrow’s events from your calendars in the Agenda app.
To view events in the Agenda app:
  1. Open the Agenda app
    on your device. You’ll see the events scheduled for today and tomorrow. Swipe up and down to scroll through the events.
  2. Tap any event to see details.
Note that the Agenda app shows up to 40 total events over 2 days. You must allow the Agenda app to access your calendar and run in the background. For more information about adjusting an app’s permissions, see How do I install and manage apps on my Fitbit device?
Let me know the outcome.
I don't have"apps". I only have Gallery, Spotify, Wallet, How to Use and Accessories. I have brand new Charge 4 and the app is up to date.
@SunsetRunner
The newest app has the Apps section under Gallery.
Gary D.| Feeding Hills, MA MBG PE
Pixel Watch 3, Pixel Watch 4
Thanks! I did finally find it just by clicking on everything.
It’s amazing how many things Fitbit posts on these bulletin boards and then you try to go in and do it on your device and it just doesn’t exist. There’s no other company that has so much false advertisement that I know of
This actually doesn’t exist when a real user tries to go in and do it. Surprise another bogus FAQ from Fitbit
I have checked for updates and I still don’t have a apps app, I only have gallery, Spotify, Wallet and How to use. I have been trying to set up my agenda for ever.
@Otterboy
Click on Gallery, then Apps at the top of the screen.
Help!  I tried to follow the instructions step by step, but i cannot find STEP 2!  Have android and versa 2
To install an app:
With your watch nearby, in the Fitbit app
  • tap the Today tab
  • then your profile picture
  • then your device image.
  • Tap Gallery then the Apps tab
Browse the available apps.
When you find the one you want to install, tap it.
Tap Install.
Some apps require certain permissions in order to work properly, such as access to the internet or the ability to run in the background.
Review these requested permissions and tap Install to add the app to your device. Note that some permissions can cause your phone to use more data.
If you decide at a later time that you don’t want an app to have certain permissions, you can adjust these permissions.
