01-12-2020 09:55 - edited 09-24-2020 19:06
Can't add weather or repair to my phone android.
01-13-2020
04:06
08:47
01-13-2020
04:06
08:47
Welcome to the Community, @SunsetRunner.
To set up the Weather app on your Charge 3, make sure to be doing the following:
If the weather doesn't update, check the following settings:
If you change locations, sync your device to see your new location in the Weather app.
To change the units used for the temperature in the Weather app:
Let me know the outcome. 🙂
04:06
08:47
01-13-2020
04:06
08:47
Best Answer01-20-2020 00:10
01-20-2020 00:10
Instructions help also I found out it was better to have my Bluetooth off on my home computer...when your cell bluetooth is on both will sync together without any problems... thanks
