01-04-2019
07:49
14:31
01-04-2019
07:49
14:31
I accidentally started a running timer and can't switch it off. My fitfit thinks ive been running for over 4 hours and ive bearly moved from my seat trying to switch it off. Help!
02-06-2020 10:18
02-06-2020 10:18
Best Answer02-06-2020 10:52
02-06-2020 10:52
Best Answer02-08-2020 08:26
02-08-2020 08:26
Omg, Thank You!!!
Frustrating for sure!
Best Answer02-11-2020 19:23
02-11-2020 19:23
I had the same issue, had me exercising for 6 hrs 42 minutes b4 coming here to get help. Help was right below this onw
Best Answer02-12-2020 14:49
02-12-2020 14:49
I am on my third replacement device and it still freezes up and won't end an exercise unless you do a complete reset. Very frustrating! It also does not auto recognize the number of exercises advertised and you end up having to start and try to stop each specific exercise session.
Best Answer02-12-2020 15:06
02-12-2020 15:06
I still cannot get mine to turn off. Any further suggestions?
Best Answer02-12-2020 16:21
02-12-2020 16:21
Best Answer02-13-2020 09:40
02-13-2020 09:40
Best Answer02-22-2020 08:17
02-22-2020 08:17
When everyone says "button" what are you referring to? I just got my Charge 3, accidentally hit start an exercise and I can't turn it off. There is a small "x" in the upper corner that you think would do the trick but it just swipes the screen. I do need instructions for this thing because the app is USELESS
Best Answer02-22-2020 09:13
02-22-2020 09:13
Best Answer02-22-2020 09:48
02-22-2020 09:48
02-22-2020 16:43
02-22-2020 16:43
02-23-2020 12:04
02-23-2020 12:04
Best Answer02-23-2020 12:05 - edited 02-23-2020 12:35
Been there. Hit button on the side of the watch twice and then push finish on the screen. I've had some success with the exercise feature but choose to just sync the fb with my phone where I get the stats I need.
Best Answer03-03-2020 14:55
03-03-2020 14:55
Best Answer03-07-2020 03:04
03-07-2020 03:04
This is a totally unhelpful response. I have NO IDEA how to open the exercise app. It opened spontaneously while I was out to dinner and then vibrated at me all through the meal, nearly driving me crazy. AND because I had to leave at a set time I had to check the time on my phone, which is far more obvious and rude. As others have said, an actual manual that gives you diagrams and step by step instructions about how to use things would be really, really helpful. I didn't even know I *had* a button until tonight. It doesn't look like a button to me, since it's recessed into the device, not sticking up as buttons usually do.
Best Answer03-07-2020 03:20
03-07-2020 03:20
In general it is simple enough to use, but too many pushes to get things done. And did you forget to stop an expressive no way to edit afterwards, but a lot of calories burned. I actually packed mine away now for these reasons plus the floor and step count not close to accurate. I do a simple workout on a flat floor and get 15 floors claimed. I take a few steps to the kitchen and back and it adds quite some extra steps. I'm back to my withing as I have their scale and other stuff so all integrated in one app. Not that the withing is excellent either, but ok for my purpose.
Best Answer03-07-2020 14:53
03-07-2020 14:53
Best Answer03-07-2020 19:59
03-07-2020 19:59
Best Answer03-08-2020 01:43
03-08-2020 01:43
You may want to consult fitbit's site where you get the full overview:
https://help.fitbit.com/articles/en_US/Help_article/2395/?q=Charge+3&l=en_US&fs=Search&pn=1
