01-04-2019
07:49
14:31
01-04-2019
07:49
14:31
I accidentally started a running timer and can't switch it off. My fitfit thinks ive been running for over 4 hours and ive bearly moved from my seat trying to switch it off. Help!
07-20-2020 07:39
07-20-2020 07:39
This is so true. Go basic. The new ones are pretty but they add too many features and besides being confusing it makes them more prone to malfunction. Husband threatening to get me a Jitterbug phone!
Best Answer08-18-2020 19:04
08-18-2020 19:04
@amtojsingh88OMG thank you so much. I just kept swiping and swiping on the side with the sensor and finally the FINISH icon came up and I could stop it. None of the other suggestions worked for me. Thank you, thank you, thank you.
10-10-2020 14:13
10-10-2020 14:13
I'm a twenty something with good eyesight and it isn't made for us either. I have the same issues as you.
Best Answer10-11-2020 05:36
10-11-2020 05:36
Hi, first of all I'd like to say that its not a button t
Its not a button at all, its more of a notch & didn't even notice it. Had charge 3 for 2 weeks & its a total nightmare, versa easier to use. Needs a real overhaul because not user friendly at all. You should be able l e to touch the screen to stop running mode etc, no fiddle pressing the side then pressing the screen to stop then again to record. Not sure who desined but wants to try using it sometime
10-20-2020 10:14
10-20-2020 10:14
Thanks for this info! It's crazy not to be able to end an exercise.
Best Answer12-06-2020 06:30
12-06-2020 06:30
Thank you OldBob!! I had to connect mine to the charger then stab the indented "Button" rapidly and was able to get to the prompt where I could stop the exercise that I never wanted to start in the first place! This device (Charge 3) is not user friendly or intuitive. This is coming from an IT person.
Thanks again,
BL
Best Answer12-06-2020 09:12
12-06-2020 09:12
Best Answer01-22-2021 02:29
01-22-2021 02:29
Thank you for this advice. Ive been googling ways to stop whatever timer is running on my watch and this is the first time i have seen anybody say to tap the side buttons twice quickly!! Immediately the finish button came up and I could cancel it! Ive been doing some kind of exercise for nearly 15 hours now lol. As you mentioned its a shame that fitbit cant just give that simple piece of info out!! Thank you for your help OldBob3301
Best Answer01-22-2021 05:43
01-22-2021 05:43
Best Answer02-09-2021 07:21
02-09-2021 07:21
I am also having this issue. Did you ever get it fixed?
Best Answer02-09-2021 13:16
02-09-2021 13:16
Best Answer11-10-2021 00:20
11-10-2021 00:20
Hey there, i dont have the option under any exercise app to set a pause, im on a charge 3, latest firmware.
