01-30-2020
10:14
17:16
01-30-2020
10:14
17:16
I really mis the exercise shortcut for the hometrainer. Exercise that aalot of people use. Any else.
01-30-2020 11:45
01-30-2020 11:45
Welcome to the forums!
When something is not listed use workout mode on your Device.
Set up a custom activity for hometrainer. When it syncs you can rename it.
There are to many different exercises out there to list them all and this is a good all turnative
Wendy | CA | Moto G6 Android
01-30-2020 12:05 - edited 02-23-2024 03:45
Hi there @Sonnetje, welcome to the Community Forums.
As my friend @WendyB said, when a specific exercise is not available within the exercises we offer, we suggest to use "Workout". Once you finish your exercise, you can rename the activity to hometrainer.
Please note that when renaming the activity from Workout to Hometrainer, the information to enter will change depending on the nature of the exercise. To give you an example if you change a workout to Run, it wont remove the calories but will add distance and this happen depending of the activity you are categorizing.
For more information, see How do I add, edit, or delete Fitbit data and activities?
Let me know if there's anything else I may do to help you.
01-30-2020 12:55
01-30-2020 12:55
Ok I didn't no that. Gonna try tomorrow. Thanks.
01-30-2020
13:59
06:42
01-30-2020
13:59
06:42
@Sonnetje What do you mean by a hometrainer? Sometimes there are different terms in different areas for the same device. By hometrainer, do you mean an elliptical cross trainer? To some people, a hometrainer is a bike home trainer. You remove the rear wheel of your bike, attach the home trainer and bike indoors.
There might be a better option than Workout.
Laurie | Maryland
01-30-2020 23:51
01-30-2020 23:51
It's an exercise bike. Stationary. Just like what you explaine.
01-31-2020 02:55
01-31-2020 02:55
@Sonnetje If you mean something like this, then the correct choice is Spinning.
Laurie | Maryland
