01-02-2017
16:58
10:13
01-02-2017
16:58
10:13
Brand new to Fitbit here & I'm trying to figure out how to track my Flow Yoga class on my Charge HR. I followed the steps in an earlier post by going to Exercise Shortcuts, but yoga seems to be grayed out. Can anyone help me figure this out?
04-16-2017 23:00
04-16-2017 23:00
Thanks!!! That worked for me.
Best Answer04-19-2017 18:29
04-19-2017 18:29
Thanks...your post was simple, and easy to follow....I now can track my yoga practice!
Best Answer04-24-2017 06:29 - edited 04-24-2017 06:31
Hi everyone! Happy to hear that the instructions in this thread help you logging your yoga activity. Feel free to select the post that helped you as a solution so it can help other members with the same question as I am not sure if it was @Rich_Laue, @Hilary55 or mine post that did it. Still thank you all for your feedback!
I'll be around!
Best Answer06-19-2017 21:01
06-19-2017 21:01
Thanks a lot! It worked for me😊
07-25-2017 22:51
07-25-2017 22:51
Worked like a charm thanks! Charge 2
Best Answer08-29-2017 22:16
08-29-2017 22:16
your explanation is clear and very helpful. thank you
Best Answer01-09-2018 18:11
01-09-2018 18:11
I have went into exercise shortcuts and added yoga, but, it still does not recognize it. What am I doing wrong?
Best Answer01-09-2018 18:46
01-09-2018 18:46
01-10-2018 02:49
01-10-2018 02:49
Have you synced the tracker since 7 adding yoga?
Best Answer01-15-2018 13:42
01-15-2018 13:42
I have got he same problem with my charge 2, I have added yoga to my exercise shortcuts as suggested but my Fitbit has not registered this can anyone help???
Best Answer01-23-2018 07:01
01-23-2018 07:01
Thanks! Very helpful. Expected to see a yoga icon on dashboard, yet did see it on fitbit watch.
Best Answer02-20-2018 10:43
02-20-2018 10:43
These instructions worked for me, thanks
@Hilary55wrote:Go to your personal profile, then in the left hand column under devices select Charge2 to view the device settings. Scroll down until you get to Exercise shortcuts and click on the blue Edit Exercise Shortcuts link. This will display the full range of options available. But you can only select 7, so you will need to deselect one or more of the options you don't use to enable you to include Yoga in your choices.
Then sync your tracker and Yoga should then be available as one of your exercise options.
If this works for you, please remember to mark this post as a solution so that other people will be able to find it too.
Best Answer03-27-2018 11:48
03-27-2018 11:48
Once youve got to the excercise option by pressing the button on the side of your fitbit charge two until it says Run, tap the screen and the excecise option will change. You can also adjust the excercise list order through settings on the app. Tapping the screen will always cycle the options for whatever catagory youve selected.
Best Answer01-12-2019 19:23
01-12-2019 19:23
Thank you so much. Clear instructions and easy to activate.
Best Answer05-05-2019 03:04
05-05-2019 03:04
Thank you very much! It work to with the Fitbit Charge 3
Best Answer10-14-2019 22:00
10-14-2019 22:00
I can't get the yoga to work anymore on my Fitbit charge 2 either. I know it use to be an option.
