10-04-2020
12:31
16:17
10-04-2020
12:31
16:17
Hi, could you please advise how I can turn off my DND. I keep missing calls.
Thanks in advance.
03-31-2021 10:46
03-31-2021 10:46
Hi, @StephFishStar, welcome, I suggest you "reboot" your device as advised in my earlier post.
Cheers
Gr4ndp4 | UK
Best Answer03-31-2021 14:47
03-31-2021 14:47
I have done it all! Rebooted etc. Turned off sleep (might have been an oversight!) received a buzz to say I hit daily target but no other notification.
thanks
04-01-2021 06:34
04-01-2021 06:34
Hi, @StephFishStar, welcome. If you have received a notification this may indicate your notification settings in your phone app need reviewing and adjusting. Touch your icon in the top left corner of the today screen on your phone app>Charge 4 tile>notifications. Ensure the slider on the right is in the "on" position, touch each heading in turn to set the source and the slider in the "on" position. Return to the today screen and sync.
I hope this helps.
Cheers
Gr4ndp4 | UK
04-20-2021 13:50
04-20-2021 13:50
I haven't been able to turn off DND since the update this past weekend. Is there any other way to turn it off? I haven't found any.
04-22-2021 10:46
04-22-2021 10:46
Hi, @Godo1960, have you tried the "Reboot" process described earlier?
Cheers
Gr4ndp4 | UK
Best Answer04-23-2021 09:58
04-23-2021 09:58
After the last update I cannot turn off DND. I have rebooted the device twice. Any fix for this out there?
Best Answer04-23-2021 11:45
04-23-2021 11:45
Hi, @Godo1960, allowing you have tried the "reboot" and are not experiencing any other identified malfunctions I suggest you talk to "Customer Support" here, I recommend you use the "Chat" facility or phone for a prompt response. Good luck.
Cheers
Gr4ndp4 | UK
05-10-2021 12:17
05-10-2021 12:17
Hi @Gr4ndp4 really confused with DND. I want to receive exercise notifications, for some reason they have stopped! When I hold for DND should it be greyed out or have the white circle with line in the middle? When greyed out and I then go to settings, DND says off but then exercise notifications are greyed out but does say on. HELP!!! please
Best Answer05-11-2021 01:46
05-11-2021 01:46
Hi, @Girlscanat50, When the DND icon is greyed out it is off. If you swipe left to "Settings" and then up and touch DND, you should see "DND Off".
Swipe up again to "Active Zone Minute's notifications". To toggle between off & on touch this icon. Explore other notifications in the Fitbit App on your phone.
I hope this helps but if you are still stuck please post here again.
Cheers
Gr4ndp4 | UK
Best Answer05-11-2021 11:01
05-11-2021 11:01
Thank you, fingers crossed 🤞
Best Answer07-24-2021 06:24
07-24-2021 06:24
It doesn't work. DND keeps turning itself on when I have turned it off. Is there no other way to switch it off permanently? I keep missing my notifications to move when I get busy at work - sometimes I have only a few steps left to hit 250. It's really very annoying.
07-24-2021 09:54
07-24-2021 09:54
Hi, @EdwinKW, welcome to the community. May I suggest you check your sleep settings? If "Sleep" is on it disables notifications, screen wake, and dims the screen. You should also check your "Sleep schedule" settings as this is what may be engaging and disengaging your "notifications". See pages 18/19 in the manual. This article may also shed some light on your problem How do I get notifications from my phone on my Fitbit device?
I hope this helps.
Cheers
Gr4ndp4 | UK
09-23-2021 08:23
09-23-2021 08:23
This finally worked for me... thanks
Best Answer11-19-2021 06:00
11-19-2021 06:00
Thank you! I got it to work.
Best Answer02-20-2022 03:07
02-20-2022 03:07
My Fitbit is dim, doesn’t respond when I tap it, and doesn’t alert me with my iPhone functions. I thought it was in DDD mode, but that isn’t the solution.
What should I do??
Best Answer02-20-2022 03:10
02-20-2022 03:10
It was in Sleep Mode!!
I found the solution. Please disregard my question. Thank you 😊!!
Best Answer03-22-2022 18:15
03-22-2022 18:15
This answer to the dnd turning on does not work for me. I followed this answer to turn DND off, them check it and send is back on. This cycle keeps repeating. How can I permanently turn dnd off?
04-03-2022 14:56
04-03-2022 14:56
I have tried all recommended actions. However none seem to work.. No matter what I do I can't seem to get back to the main time screen. Can anyone help ?
Best Answer01-15-2023 23:06
01-15-2023 23:06
I have the exact same problem and have tried all the suggestions but DND remains on. Did you solve this issue? It is extremely frustrating.
