04-01-2019
13:16
11:10
04-01-2019
13:16
11:10
I touched my Fitbit charge3 after reaching my daily goal and the gospel connected notification on my phone showed up as well the Fitbit keeps running a countdown and vibrating. I want to turn it off and get back to just the time on the first screen
04-02-2019 09:12 - edited 04-02-2019 09:12
Welcome to the Fitbit Community @TriniGail! Charge 3 can track runs with GPS automatically. After you start to run, the Exercise app opens to track your real-time stats, including heart-rate, pace, distance, and GPS route. Run tracking may take a few minutes to start. You must have your phone nearby to use connected GPS.
You can also customize various settings for each exercise type right on your device. For example, choose to:
To customize your settings:
Let me know if this answers your inquiry.
10-22-2019 00:28
10-22-2019 00:28
So how do I grt it to automatically turn off GPS after excercise?
10-22-2019 03:44
10-22-2019 03:44
@marcoscu That connection from your tracker to your phone gets turned off when you end the exercise.
Is your Charge 3 behaving in a way that you think it is still connected?
Laurie | Maryland
10-22-2019 04:06
10-22-2019 04:06
10-22-2019 05:38
10-22-2019 05:38
@marcoscu I'm sorry that I can't help you with your connection issue. I am an iOS user and I have never experienced this issue. Nor have I experienced the other issue you describe. I hope that an Android user reads this post and has some advice for you. If no one chimes in on this forum, I suggest you start a new thread on the Android forum. Sounds like a setting issue.
Laurie | Maryland
10-22-2019 08:02
10-22-2019 08:02
10-22-2019 15:57
10-22-2019 15:57
From piecing together the constructive comments, I came up with the fix (at least on my wife's device)
You push the button on the side until you get to exercise.
Then slide to the left or right until an exercise appears.
DO NOT tap the screen.
Swipe up and you will see the options for each exercise.
If GPS is turned on, tap GPS and it will go to off.
You might also want to turn off the Auto Detect for that exercise.
NOTE: Not all exercises have the same options, and some of them don't have GPS at all.
The really sad thing is you paid for this option, but as with most fitbit add-ons, they suck battery, and rarely work correctly,
10-24-2019 05:33
10-24-2019 05:33
Unfortunately, the "so called" best answer doesn't address the question. And did the person who worte it even consider that not everyone on this forum is as familiar, or device literate, as you think you are.
Read the question. Her fit bit activates the exercise program, and then will not allow her to terminate it. Your answer was basically the same information word for word in the manual, and it doesn't address the problem.
I did not have the problem. I was helping that person out with a solution that works - not a "Cut and paste" that doesn't come close to helping resolve her issue.
01-24-2020 03:38
01-24-2020 03:38
When you say “on the device, open the exercise app>run” what does that mean? By device do you mean the Fitbit app on my iPhone? Or the Fitbit device itself?
And, what do you mean by exercise app? Do you mean the exercise section of the Fitbit app once it’s opened which takes work to find and just shows stats. Or do you mean the Fitbit app is the exercise app? And if so, where is “run”? It would be useful if my app looked like this because I can’t figure out how to do anything other than read endless stats. I want to know how to turn run detect on and off, etc. When I swipe up on my charge 3, again stats but no way to turn anything in or off.
01-24-2020 06:17 - edited 01-24-2020 06:26
I fully agree with you.
It seems like even after having this thing for a year we have to do
everything twice or three times or more.
Changing anything is a major chore, not to mention a guess, because most of
the time it goes back to the adjustment you were trying to get rid of the
next day.
And of course, every time there's an update, everything resets back to
default(?) or to what they want you to use from the update.
I keep saying when this one dies, I'm through with Fitbit devices, but
we've bought three more since the first time I said that.
I must like aggravation and ansiety.
P.S. I wish I could get a moderator job at Fitbit. All you need to know how to do is Cut and Paste.
You don't have to read the issue, just find one word, and paste a response that uses that word.
The moderator is probably a computer program, that does exactly that.
02-02-2020 13:09
02-02-2020 13:09
Dear Fitbit
I am trying to use gps tracking but it looks like my Fitbit exercise app does simply not foresee the possibility to choose gps tracking. I can choose autodetect, but besides this it is only indicated (in grey, without on/off switch) that gps tracking is not active. Do I need to install another app?
Thanks on beforehand for your advice!
Maarten
05-26-2020 06:33
05-26-2020 06:33
You are correct. The best answer doesnt solve the issue. In fact, it completely missed the point.
My Fitbit has started operating quite erratically lately, including not recording exercise I do (yes, standard things like running, walking, aerobics) that are in my auto record list) and just recorded a phantom run in my sleep....0.04 miles all while lying flat on my back. It took me 45 minutes of fiddling with it to get frustrated enough to look here and thanks to your answer I got it off. Now just to figure out how to edit those calories and steps to eliminate the ones I didn't take!
05-26-2020 13:03
05-26-2020 13:03
Alanae:
I responded to your kind words, but the Fitbit moderator couldn't take a little criticism, so they marked my response as SPAM and deleted it.
I did notice one of previous replies addressed some of the same issues, but two posts doesn't constitute SPAM.
I hope you see this before they delete my comment again.
Fitbit Support has turned into a call center, and the moderator comments on these forums are just "Cut and Paste(s) based on a single word that they see in your complaint, or question.
I worked in a Support center for 13 years before I retired, and they're no longer support centers.
They're Call centers, and employees are evaluated on how many calls or responses they make in an hour. Calls are closed automatically, if they send you a response, and you don't respond and tell them that the issue is not resolved. Their fondest wish is that you don't call back, or respond to their Cut and Paste solutions, that more often than not, have nothing to do with the issue you reported.
Good luck finding a phone number, and/or speaking to a human. At one point i had their phone number saved on my phone, but average wait time often ran close to an hour. I deleted the phone number after a particularly annoying instance of Some foreign Elevator music, interrupted every 40 seconds, by a recorded message telling me to patient, due to high call volume.
06-19-2020 08:00
06-19-2020 08:00
Followed all these steps and turned it off but It is still running
06-19-2020 13:53
06-19-2020 13:53
I'm sorry to hear that. I haven't had the issue for over a year now. The only thing I can suggest is go thru it one more time.
I do seem to remember that after a Fitbit update all of the settings went back to default and I had to go through the process one or two more times.
08-18-2020 07:55
08-18-2020 07:55
If you want the GPS off check the weather feature that is where I turned it off and it seemed to end the constant syncing and message that GPS was running in the background
