10-25-2017
06:06
06:26
JuanJoFitbit
10-25-2017
06:06
06:26
JuanJoFitbit
how to turn on all day sync
Moderator edit: updated subject for clarity and format.
10-26-2017 10:19
10-26-2017 10:19
A warm welcome to our Fitbit Community family @tcnaper!
This is an excellent questions, to activate the All-day Sync option in your mobile device, please go to the Fitbit application, tap on the account tile and select your tracker's name, once you're there, scroll all the way down and toggle All-day sync, please check the pictures below:
Hope this helps, let me know if you have questions.
What's for breakfast?Check others recipes and share yours!
10-26-2017 11:32
10-26-2017 11:32
10-27-2017 07:48
10-27-2017 07:48
Great to see you again my friend @tcnaper. It's always nice to work with awesome Fitbitters like you! I'd to invite you to continue digging in our Community, you can find here the option to suggest your ideas to change and improve our products and services, you can also find awesome discussions where you can make new friends, find other Fitbitters sharing their experiences and motivation and much more.
Hope to see you around the forums!
07-14-2020 05:26
07-14-2020 05:26
I do this but I don't even see the option to turn on all day sync on my versa lite. It literally isn't there. What do I do?
07-18-2020 13:32
07-18-2020 13:32
Yep the option is gone???!
07-18-2020 23:36
07-18-2020 23:36
07-18-2020 23:36
07-18-2020 23:36
Same. Mine doesn’t show the option
07-22-2020 12:28
07-22-2020 12:28
I don’t have the “all day” option
07-25-2020 13:31
07-25-2020 13:31
I don’t have an All Day Sync option on my app! It just isn’t there. More do I have that pink update button. Got my charge 4 24 hours ago and feel like it’s missing things!
08-04-2020
02:02
04:25
JuanJoFitbit
08-04-2020
02:02
04:25
JuanJoFitbit
The option to turn on All Day Sync is gone from the app.
How does one enable All Day Sync now or is it automatically enabled?
Hi Marlen - this string requires attention. Several users with the same issue and your Solution is no longer valid as the options you show in your screenshot are gone.
Moderator edit: merged reply
08-04-2020 06:41
08-04-2020 06:41
08-17-2020 07:14
08-17-2020 07:14
I simply cannot find the all day sync option in my Fitbit versa. I have looked and looked within the mobile app. How to find?
08-18-2020 02:13
08-18-2020 02:13
The "all day sync" option has been removed from the app. It is now on by default and cannot be turned off. Fitbit say:
"To improve your experience with notifications, syncing, and firmware updates, we removed the option to turn off all-day sync from the Fitbit app. When your phone is near your Fitbit device with Bluetooth turned on, it periodically syncs with the Fitbit app to update your stats and download available firmware updates. More frequent syncing rarely, if ever, noticeably decreases your device’s battery life."
Taken from: https://help.fitbit.com/articles/en_US/Help_article/1877.htm
08-18-2020 06:00
08-18-2020 06:00
Thank you so much. That explains it!
09-02-2020 12:30
09-02-2020 12:30
That stinks! Put it back! It should be our choice to use or not, not yours. I just got the new fitbit charge 4 and it is terrible. I may return it as I've had nothing but trouble. I just want to use it and have it work properly. 😞
09-02-2020 13:13
09-02-2020 13:13
Though one post said it syncs all day, mine does not. I have to open it, and manually start the sync. It’s so frustrating!
09-05-2020 10:16
09-05-2020 10:16
I do not have the option to turn on all day sync. Only sync now.
09-07-2020 10:44
09-07-2020 10:44
Mine is the same. I constantly have to update it through the day as it's not syncing by itself... very frustrating, when u want see your sleep quality and exercise impact..
09-23-2020 06:02
09-23-2020 06:02
No longer valid as 'all day sync' is now default. However..... Its not, having to open app to sync
