02-26-2021 15:57
02-26-2021 15:57
I am getting too many alerts.
02-27-2021 06:45
02-27-2021 06:45
Hello @clj810, welcome to the community forums!
To remove calendar notifications, I suggest you to follow the steps below:
1. From the Fitbit app, tap on your profile picture and then tap your device image.
2. Tap Notifications
3. Tap the type of notification you would like to disable (Text Messages, Calendar Events, Emails, or App Notifications), and make sure it's turned off.
Sync your device.
Hope this helps!
