12-01-2018 03:44 - last edited on 11-17-2020 14:34 by MatthewFitbit
I have tried to go setting in app.on mobile and follow the guideline from community. However, i can't add or remove auto recognized excercise. So, How do i add yoga as exercise on fitbit charge 3? Please help.
12-01-2018 05:10
12-01-2018 05:10
In your app go to your charge 3 (little tracker icon in the top right corner) and scroll down to Exercise shortcuts. Select that and on the page that comes up is the list of shorcuts you have on your charge 3. If there are 6 in the list delete one by swiping to the left, then select the plus sign in the top right. You can then select Yoga off the list of 15 shorcuts available. Then sync your tracker and Yoga shoukd be on the Charge 3.
Helen | Western Australia
12-01-2018 05:10
12-01-2018 05:10
12-06-2018 06:26
12-06-2018 06:26
This didn't work on my Charge 3
12-19-2018 19:20
12-19-2018 19:20
There is no Exercise shortcut on the Windows 10 app, and I can only ignore one of the listed options without being able to add new ones (like Yoga). I did a Yoga session, but the auto detect function did not recognize this either. Does not help my motivation. Now I'm just tracking manually via MyFitnessPal, but I don't need a Charge 3 for that.
12-26-2018 03:36
12-26-2018 03:36
I just don't understand why this says resolved question. People have just written what is on the instructions for the watch which doesn't seem to tally up for half the uses. I don't get these options on my charge 3 either, there is no short cut to exercises option. One of the main things I want to track is yoga, and there is no settings to add or delete different exercises to track.
I'm on an Android version of the app, has anyone worked this out?
12-26-2018 12:51 - edited 12-26-2018 12:52
Hi Karms, I have worked it out, but through my laptop by going to the Fitbit site online, because the option does not seem to work with the App for the Charge 3. If you go to www.fitbit.com and log in, you can follow the instructions click on the little cog in the right upper corner and then on the Charge 3 pic (NOT on Settings!), the list opens that shows 'Exercise shortcut'. There you can edit the options and also shuffle the list with your preferred activities. After doing this, Yoga shows up on your Charge 3 also. On my side the Auto recognition still does not work for Yoga, and I constantly forget to start it manually, so I just still catch up in the evenings though MyFitnessPal. Ah well.
Hope, that helps!! 🙂
01-11-2019 13:54
01-11-2019 13:54
Swipe left doesn't work. Only option is to deselect and save to ignore. No plus sign to add and no list to find yoga on for adding.
01-20-2019 09:28
01-20-2019 09:28
I have an Android and the instructions she gave me to add to the exercise shortcut worked. The only.thing is I added yoga after I did you so of course it didn't track it. I was hoping when you click to track an exercise one of the options would be yoga but instead it is just run, walk or hike. So i guess i will just have to press play next time just in case it doesn't auto recognize🤷:female_sign: Im new to having a fitbit so not 100% sure.
01-22-2019 11:54
01-22-2019 11:54
Thank you, this fixed it for me!
02-20-2019 12:28
02-20-2019 12:28
my Charge 3 does not have the exercise shortcuts. How do I find it?
02-20-2019 18:21
02-20-2019 18:21
If you go on your fitbit app, click on the charge 3 in the upper right, scroll down to exercise shortcut and click on it. You can only have 6 and to delete one swipe left and then add a new one if needed. Hope this helps!
02-21-2019 08:10
02-21-2019 08:10
The icon to touch to add exercise on my new fitbitcharge3 is on the upper right of the dashboard screen, not the left side. Also the icon is not a gear but a watch. You'll find the Exercise Shortcuts after pressing the watch. You must delete one type of exercise to add yoga.
02-21-2019 08:11
02-21-2019 08:11
Now I'm replying to my own post. The watch icon is on the left side of the dashboard, not the right.
02-21-2019 08:13
02-21-2019 08:13
03-20-2019 19:20
03-20-2019 19:20
Thanks for the clarification. Logging in on my computer allowed access to the required settings as you explained. Your instructions worked perfectly!
04-21-2019 06:07
04-21-2019 06:07
Thanks NellyG. I was able to add Martial Arts by following your instructions. Worked perfectly.
07-23-2019 22:14
07-23-2019 22:14
Updated working solution for new app [2019] :
Click on upper leftmost corner icon of your profile > Devices > click on your device > scroll down and goto General > Exercise Shortcuts > Swipe left on any exercise you want to remove.
Now click on + and you can add your favorite exercise from the list.
07-24-2019 04:21
07-24-2019 04:21
Thanks! I got it now!😊
12-25-2019 08:44
12-25-2019 08:44
Thank you for this! I was getting very frustrated, LOL!
02-18-2020 03:44
02-18-2020 03:44
You are a legend, Thank you 🙂
