09-21-2019
02:10
10:40
09-21-2019
02:10
10:40
Ive followed the instructions to change excercise shortcuts but when I get there there is no gear icon to allow me to edit? How can I do this?
09-21-2019 03:05
09-21-2019 03:05
Hello @Salhil99 and a warm welcome. The page you are showing is the page that lets you change the apps on your Charge 3. I will help you get to the correct page.
From your app dashboard > tap on your profile picture > tap on your Charge 3 tile > swipe up on the screen until you see Exercise Shortcuts and tap on that. Now you are on the list of Exercise Shortcuts. There is an edit option that will let you delete, add and arrange the exercises to the order you want.
I hope this helps.
Laurie | Maryland
08-05-2020 18:03
08-05-2020 18:03
Dear Laurie,
Thanks for the tips; it works! I did have to adjust your directions since I was on a desktop PC. May I suggest adding steps to your post if you are on a desktop computer? And also add a note that the change to the Versa watch is not immediate, but only after you log off from your online account (I might be mistaken on the second suggestion; please adjust as needed).
Thanks again!
Warm regards,
Bob
