How far can you go without your phone?
How far can you go away from your device with your fitbit on?
5 REPLIES 5
You can go as far as you want to but they will only communicate with each other for about 20 feet or so (variable).
C.B.
@Nabeelk, that depends upon whether you are using the Connected GPS function, or receiving Notifications from the phone to the tracker.  If you don't need either of those, you need not have your phone with you at all.  If you want to use either of those, though, you are limited by the Bluetooth range of about 20 feet.
A Fitbit only needs your phone or tablet or computer to sync your data to the app. You can go as far as you want. As long as your charged up the Fitbit will keep your data till midnight. You need to be close to your device to sync though.
Thomas (Atomic77)  WATCH SE 2nd GenFitbit aria Air scale
Thank you
Hi was wondering since this post is from 2017 if this has changed with the newer models? I have the Versa 2
