01-06-2017
		09:55
		10:13
		01-06-2017
		09:55
		10:13
How can I add my Tai Chi practice to my fitbit exercise totals?
01-09-2017 12:49
                                          Community Moderators ensure that conversations are friendly, factual, and on-topic. We're here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
                              01-09-2017 12:49
Welcome to the Fitbit Community @ShifuH. It's great to have you here. You can use Workout from the Exercise Shortcuts on your Fitbit Charge 2 to track your Tai Chi practice. If you don't have this option please go to the online Dashboard > Settings > Devices and scroll down until you see Edit Exercise Shortcuts. Add Workout and force sync by following @WendyB's instructions.
To select an exercise from your tracker Exercise Shortcuts you can press and hold the side button, over the exercise you'll track, until you see a stopwatch.
Let me know how it goes. Thanks for stopping by, see you around. ![]()
 Best Answer12-02-2017 13:53
12-02-2017 13:53
there is NO tai chi setting? I used yoga as a similar exercise but it still doesn't register ...only the steps I take. I also want it to sinc with my Myfittnesspal. for calories burned. HELP!!!
01-19-2020 17:18
01-19-2020 17:18
The strange part is that if you go into your exercise log and manually add an exercise, Tai Chi shows up as an available exercise. Why you can't add it to shortcuts is a mystery to me.
I found a temporary workaround. I used several calculators, and Tai Chi seems to burn almost the exact same calories per hour as Pilates. Since Pilates is an available exercise for shortcuts, I'm using that to log my Tai Chi sessions.
01-19-2020 17:22
01-19-2020 17:22
