10-06-2018
07:15
15:47
10-06-2018
07:15
15:47
I haven’t got the option to have Fitbit pay (wallet app) how do I get it
Moderator Edit: Updated Subject for Clarity
01-16-2020 17:53
01-16-2020 17:53
I would think if you have set it up you have the special edition.
I assume when you setup you mean that you have registered a credit card onto you fibit with the "wallet" option in the app.
01-16-2020 18:02
01-16-2020 18:02
Sandovalmp
You need to set up a pin. You will notice that the centre number is bright - scroll through the numbers and and tap on the digits in order of your pin number, say 1,2,3,4. You have to use the app to set up a pin to enter payment mode
01-25-2020 18:57
01-25-2020 18:57
I have the Payment tab on my Fitbit Charge 3, but can’t seem to find the Wallet tab on the mobile application. Does that mean my Fitbit Charge 3 can or cannot use Fitbit Pay? I am very confused
01-27-2020 04:06
01-27-2020 04:06
Or just get the Australian charge 3 and it comes with Fitbit pay (buy from amazon.com.au) or pay a company to import it for you
02-12-2020 04:51 - edited 02-12-2020 04:52
Hi, I have the fitbit charge 3 with furniture pay. I am using it in Australia and my device is xiaomi redmi note 5 pro. I have saved my card info in it but for some reason whenever I try to make a transaction it doesn't work (fitbit pay is opened). I have tried it on several machines and in all of them it doesn't work. The fitbit doesn't do anything.
Can you please help me with this issue?
Thank you
02-12-2020 04:55
02-12-2020 04:55
Hi, if you fitbit supporters fitbit pay, then I guess you should wait. Even I had the same issue but after the furniture app update the wallet app was there (thought it doesn't work properly). I'll recommend you to wait.
Thank you
04-23-2020 17:38
04-23-2020 17:38
I have previously used Fitbit Pay on my charge 3 but it has suddenly stopped showing on my fitbit although the payment card remains registered in the Fitbit App.
How can I get the payment card to resync onto my fitbit?
04-23-2020 21:00
04-23-2020 21:00
Hi. You should try to remove the card from the fitbit and also remove the device from the app. Then pair it again and then try to use it.
Or you can wait for sometime I happed with me as well but it got fixed after 2 days.
04-28-2020 13:39
04-28-2020 13:39
I also have this issue. I though Charge 3 supported Fitbit Pay. Should I have gone with the Charge4?
04-28-2020 16:17
04-28-2020 16:17
I deleted from the phone app and recreated the entry.
04-28-2020 20:21
04-28-2020 20:21
it had happened with me as well when I got the charge 3 I didn't even had the wallet app but after few days I got the wallet app. It's a bit glitchy in the beginning, I guess you should wait for an update of the Fitbit app, that had helped me. or try to uninstall and repair charge 3 with your phone.
