05-23-2018
10:53
20:07
05-23-2018
10:53
20:07
Number of steps taken icon disappeared from dashboard, registers on armband but can't check on dashboard, how do I get it back?
05-26-2018 04:52
05-26-2018 04:52
Welcome to the Forums @Edgebox!
Let me help you with your inquiry. To add, hide or rearrange tiles on your dashboard follow the instructions below:
Let me know how it goes!
Best Answer12-27-2018 04:47
12-27-2018 04:47
I mistakenly removed tiles from my dashboard on fitbit.com, but don't see an edit or anything. Is there a way to view available tiles and re-add any I want?
02-01-2019 13:58
02-01-2019 13:58
My app on the iPhone X doesn't have a "+" icon on the upper left or upper right of the tile. Is there anything different for iPhone X instructions?
Best Answer08-13-2019 23:09
08-13-2019 23:09
Hi, since the Fitbit app recently updated I cannot see the weight tile on my iPhone XR. I’ve noticed that it seems impossible to edit which tiles are on display since the update too
I’ve attached a photo of the view I have after clicking on ‘edit on the dashboard’
thank you in advance!
Best Answer08-26-2019 16:59
08-26-2019 16:59
If you click on discover and select health and fitness stats, you can add apps back from there
08-26-2019 23:22
08-26-2019 23:22
Thank you - this has worked
Best Answer10-11-2019 20:15 - edited 10-11-2019 20:18
Thank you! This was SO helpful. You finally had the answer that fixed my issue. Thanks again.
Best Answer06-16-2020 19:23
06-16-2020 19:23
I've also removed some tiles from the dashboard on my Tablet and the edit button only allows me to remove more. How can I view the sleep, steps. Heart rate etc and add them back to the dashboard? For fitbit charge 4
06-16-2020 19:28
06-16-2020 19:28
I've tried this but theres no response when I tap on open
