07-11-2017
19:29
09:26
07-11-2017
19:29
09:26
I would like to change my daily goal steps from 8,000 to 10,000
how do i do that.
thank you
07-11-2017 20:11
07-11-2017 20:11
Welcome to the forums!
Go to your dashboard. On the tile with your steps on it. Hover your mouse over the bottom left until you see a gear. Click on that and you will see where to change your step goal.
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
07-11-2017 20:11
07-11-2017 20:11
07-29-2017 19:00
11-11-2017 09:27
11-11-2017 09:27
I have tried your solution to changing my step goal and it does not work! When I hover over the step tile the gear wheel does appear but when I click on it the image changes to "Top Badges" and says "remove tile" followed by "done". When I click on this it just reverts to the original view!!
I have a Charge 2.
Any other advice?
Thanks.
11-11-2017 15:27 - edited 11-11-2017 15:30
11-12-2017 14:06
11-12-2017 14:06
Hi, thank you for the great instructions. The pictures are great and i was able to do what you have said,
thank you
arlene
11-12-2017 15:16
11-12-2017 15:16
Glad to here that.
10-28-2018 21:11
10-28-2018 21:11
Thanks for the screen shots. My Fitbit.com dashboard does not look like the images however (maybe difference in updates (your post was from last year) or platform (I'm on a MacBookPro). Think I've tried everything without much luck.
Best Answer10-28-2018 22:19
10-28-2018 22:19
Hello @bluepinecones are you accessing your settings through the web based dashboard?
Go go to fitbit.cm
, mouse over the today screen and then click on the cog that pops up.
To
12-21-2018 05:47
12-21-2018 05:47
Have you had any luck? I've tried the hovering over the settings icon also and nothing happens. Clicking on the settings icon only gives me the option of deleting the tile and choosing "See More" just shows me my detailed daily activity. It's frustrating.
12-21-2018 05:51
12-21-2018 05:51
Nevermind. I should not try this stuff without having a cup of coffee first - lol. I just realized that I was not hovering over the right tile. I was hovering over my Steps tile, rather than my Goals tile.
Best Answer12-22-2018 22:20
12-22-2018 22:20
I’m trying to do this on my phone app so I don’t have a mouse to hover. How can I. Do this with in the app? Instructions to go to settings doesn’t help.
12-23-2018 04:23
12-23-2018 04:23
Tap on the daily report tile, then tap the settings gear found in the top right.
Or through the web tap on a blank spot on the tile, that is how I got the screen shots posted above through the phone.
01-17-2019 03:44
01-17-2019 03:44
Thank you! This was exactly the help I needed with my charge 3.
Best Answer02-17-2019 12:43
02-17-2019 12:43
THANK YOU... I have stumbled over by accident so many times and forgot how to change when I wanted too.
Best Answer12-30-2020 09:53
12-30-2020 09:53
I'm having the same problem and results.
Best Answer12-30-2020 20:18 - edited 12-30-2020 20:23
Hi @JoyceHoffman you are ressurecting a 2 year old thread. What is the issue that you are having? Things have changed a lot since then.
Best Answer01-02-2021 06:24
01-02-2021 06:24
Best Answer01-02-2021 07:45 - edited 01-02-2021 07:45
Hi @JoyceHoffman their are two ways to change your step goal with both being described above.
