07-23-2019
13:26
14:11
07-23-2019
13:26
14:11
Hi
Activities come with some presets which cannot always be very accurate (as they may depend on each user). Is there a way to change that setting, so that one does not have to manually do it each time one does this activity ?
Example:
I would like to be able to change the sailing to be at least the same as kayaking, but cannot find a way to do so.
Any idea would be greatly appreciated.
Thanks
Gérald
07-24-2019
12:04
07:04
07-24-2019
12:04
07:04
@GerLech, welcome to the Fitbit Community! I hope you're doing well!
Let me help you with your activities calories. You can enter the amount of calories burned for an activity when you manually log it. Follow these instructions to do so.
Let me know how it goes.
07-24-2019 15:45
07-24-2019 15:45
Hi
Thanks for the reply.
Logging the calories manually works fine, that is how I started doing it, but I was wondering if there was a way to change the automatic setting that Fitbit uses for this activity instead of changing it every time (being a bit lazy here )
