How to change the clock face on Charge 3?
If I go to Account, Charge 3 and click on "Clocks," nothing happens. My Charge 2 has a "Clock Display" setting in about the same spot where I can change the main clock face.
Edit - had to do another app update, then the clock faces were available.
25 REPLIES 25
where did you find the clock face for charge 3?  I have opened EVERY option in my dashboard and it isn't there.
You change the clock face from the Fitbit app. I'm not sure if there's any
other way besides the app to change the clock.
settingssettingsI understand to change from Fitbit app, but I have searched EVERYWHERE on the dashboard, account (which just gives me my profile), all the settings and nowhere is there a clock. Any other suggestion? Where would you find the clock? Those are my settings.
>From the app select your icon on the upper left, then select the watch, and
you should see clock faces. I have the app for Android. It should be the
same for Apple where you touch your icon first.
My Fitbit changed its clock faces while I was sleeping (I do not wear it to bed). Mine doesn’t say clock or clock faces it says gallery. Why do they make it so difficult to find.
