12-03-2019
17:35
11:42
12-03-2019
17:35
11:42
The time on my Fitbit reads 7:16 PM (it is 8:35 PM) and the day reads Dec. 2, while it is Dec. 3. I Googled how to change the time and tried all kinds of things. I am lost. Thanks in advance.
12-04-2019 00:29
12-04-2019 00:29
You can't manually set the time but it should reset itself whenever it syncs to your phone or computer based on the time on that device. Does your fitbit seem to be syncing ok?
The other thing that affects the time is the timezone in your profile. You can check yours at https://www.fitbit.com/settings/profile If you do change it then you'll need to sync again to update your fitbit.
Best Answer12-04-2019 04:57
12-04-2019 04:57
My fitbit is 2 hours ahead of time. How do I correct it?
Best Answer12-04-2019 05:01
12-04-2019 05:01
@Charleslet that sounds like your timezone might be set incorrectly. I'd suggest checking it as described in my earlier post.
Best Answer12-09-2019 18:40
12-09-2019 18:40
How to set the time on a fit bit 2
The time is not right
Best Answer12-10-2019 05:39
12-10-2019 05:39
