03-01-2019
14:11
11:22
03-01-2019
14:11
11:22
I was wondering if anybody could yell me how to dismiss the alarm on my charge 3. I set an alarm for everyday of the week to go off at the same time. I touch the screen and it goes of but about 10min later it goes off again and again and again. I dont know how to dismiss it the first time to just shut off.
03-03-2019 04:42
03-03-2019 04:42
Hello @Krista73.
Let me help you dismiss the alarm on your Charge 3. I will also be moving this thread to the Charge 3 board as I think it is better suited for it.
To dismiss the alarm you have to press on the side of your Charge 3 instead of tapping the ZZZ button on the screen. Hope this clarifies the situation.
Let me know if you have any further questions.
Best Answer03-03-2019 04:42
03-03-2019 04:42
Hello @Krista73.
Best Answer04-05-2019 06:41
04-05-2019 06:41
I had a charge 2 and was able to turn my alarms off quite easily. Now I have a new charge 3 and I am having trouble turning the alarms off. I have 4 different alarms set to go off every day. I have tried to press the button on the side once which is what worked for the charge 2. I can’t get it to stop going off. I have tried pushing the button 2 or 3 times. Sometimes it works and sometimes it doesn’t. Am I not pressing the button properly. It was definitely easier to press the button on the charge 2. What am I doing wrong? What should the screen look like if the alarm has been turned off? It’s driving me crazy. Please advise. Thank you.
04-05-2019 09:39
04-05-2019 09:39
All I do is push the side button on my charge 3. I'm not sure why yours won't stop the alarm. Sorry
Best Answer04-05-2019 09:39
04-05-2019 09:39
Best Answer04-05-2019 16:08
04-05-2019 16:08
Oh gosh! Thank you for responding but honestly l thought was replying to the moderator. But really thank you for responding because if you didn’t, l would have been waiting a long time and then l would have been totally annoyed that no one responded.
Thank You
Lisa
04-05-2019 16:10
04-05-2019 16:10
Best Answer09-02-2020 03:18
09-02-2020 03:18
I can't figure out how to turn off the alarm either. For example, I am asleep and alarm goes off. I tap the button on the side of my charge 3. The alarm goes off and I decide to lay in bed and watch YouTube. Nine or ten minutes later the alarm goes off again. The thing is, I never hit snooze so why is it doing this? Come on Fitbit team...
09-22-2020 09:38
09-22-2020 09:38
that doesn’t work.
