05-12-2019
07:31
16:40
DavideFitbit
05-12-2019
07:31
16:40
DavideFitbit
Can someone help me do a factory reset on my Charge 2? I need to sell it and none of the suggested methods are working. Thank you!
05-12-2019 08:27
05-12-2019 08:27
I don't believe there is a factory reset for the Charge 2. Just do a sync after you are done wearing it to get your latest exercise data from the tracker to Fitbit computers.
And there is no personal data on the tracker itself, with no downloaded apps, credit card or music storage.
See How do I erase my Fitbit device?
Best Answer05-12-2019 10:56
05-12-2019 10:56
Best Answer05-12-2019 16:47
05-12-2019 16:47
You can simply remove the tracker from your account. Tap the garbage can found in the top right. At this point the tracker will not be connected to your Fitbit account and will need to be setup before it may be used.
Or you may simply give the tracker to the buyer, when they set it up it will be removed from your account. This is what I do when I give a tracker to a relative, since I will haves a record that the tracker was added to their account.
The tracker is registered to a Fitbit account, the Fitbit account is registered with an email address.
There is nothing with the tracker that points to your email address.
