04-08-2018
09:02
18:54
04-08-2018
09:02
18:54
I’m trying to factory reset my charge 2, is there anyway to do that? I’m asked to factory reset because it wan’t syncing so I removed it from my account and now it won’t connect.
I have a Microsoft Lumia 830
04-16-2019 23:12
04-16-2019 23:12
Best Answer05-12-2019 15:55
05-12-2019 15:55
can u please help me reset mine i want to give it to my mom . i took it off my phone 1rst it didnt reset i tried the way fitbit says and nothing ugh..
@HeydyF wrote:Hey @Jojox, welcome aboard! Let me ask you this, why do you want to factory reset your Charge 2? If you have inconveniences with your Fitbit, let me know, maybe I can help you out. 😉
I'll be around!
Best Answer05-12-2019 15:58
05-12-2019 15:58
Best Answer06-04-2019 06:16
06-04-2019 06:16
Hi. My daughter gave me her Charge 2 Fitbit. I understand that there is no factory reset on the Charge 2 and that all you need to do is create a new Fitbit account, tie the tracker to that and everything should reset. However, this tracker is not behaving that way. I created a new account in my name, setup the tracker but I am still seeing all of her steps she accumulated months ago in the app. I even was awarded "badges" because of her steps, none of which are mine. I need to eventually sync this with an app through my workplace so I need to get rid of these steps that are showing up in the app. How can I do this?
Best Answer07-18-2019 00:34
07-18-2019 00:34
Hi
i have fitbit charge 2 (2 years old) with firmware 22.55.2. all of sudden since 2 days, its charging very fast (10 mins) and then discharges very quickly as well (2-3 mins). so i restarted it as per suggestions from community, but still the same status. during the time its ON, all stats are OK, even syncs properly.
cleaned both device and charging cable for clearing out dust/debris, changed cable as well as charger, but still the same.
Can you please help for next steps. also, on android app, i have noticed, it shows firmware version as 22.22.55.2
how can i know if its just a bug or battery has really given up (does battery need replacement) or if the device has met it end ?
Best Answer01-20-2020 15:29
01-20-2020 15:29
Olá boa noite o meu charge 2 está justamente com esse problema. O que fazer ?? Ele não mostra nada na tela e o sensor do pulso fica o tempo todo ligado . Quando coloco o carregar ele mostra a bateria zerada .. quando tiro do carregador funciona uns dois ou três minutos e apaga novamente.
