How to enter my data from the Charge 3 to my Fitbit account?
Hi,
I have a Charge 3 and I'm not sure of how to enter the data manually.
I'm really not tech savvy, maybe there is a step by step of how to enter the data manually.
I'm using the Fitbit software on the iPhone.
Thank you.
Paul
Moderator edit: subject for clarity/format
2 REPLIES 2
Which data is it you are talking about entering?
Do you have your tracker set up and connected to phone, or are talking about getting it set up?
Hello @paul_faraianu. Welcome to the community forums! @JohnnyRow It's nice to see you around and thanks for your input!
@paul_faraianu Thank you very much for the detailed information. Adding to the post above, I'd like to let you know that if you already set up your Charge 3 with your Fitbit account, you will just need to sync your Charge 3 with your Fitbit account using your iPhone. Actually, syncing is the process that transfers the data your device collects to your Fitbit dashboard and for more information, I recommend checking this help article: How do Fitbit devices sync their data?
Now, if you forget to wear your Fitbit device or if you would like to have credit for an activity that isn't detected automatically, you can manually log that exercise in the Fitbit App. For instructions, I recommend checking this help article: How do I add, edit, or delete Fitbit data and activities?
Hope this helps.
Wilson M. | Community Moderator, Fitbit.
