01-03-2019
05:56
14:31
01-03-2019
05:56
14:31
I've tried following these steps for a factory reset but I do not know how you're supposed to continually hold down the side button (in the cradle with the cut out hole for pressing the button) AND be able to continue to hold it down when you remove the watch from the cable. You must let go of the button to get it out of the cradle. Can someone clarify Step 2, transition to Step 3?
To factory reset your tracker:
Moderator edit: updated subject for clarity & format
07-25-2019 07:04
07-25-2019 07:04
I have also tried all of the recommended tips and my Charge 3 is still unresponsive. Please put me in contact with Customer Support.
08-06-2019 21:16
08-06-2019 21:16
Same here. Reset doesn't work at all. Changing the clock face makes no difference.
08-14-2019 18:05
08-14-2019 18:05
I also believe the reset instructions don't work. Can someone please clarify how you can press the socalled button to reset. Also my screen is complete blank. I do not see anything.
09-08-2019 14:48
09-08-2019 14:48
Got a replacement Fitbit Charge 3. Wont let me set it up. Keeps telling me that email is already in use. I know that. It’s me!!
09-30-2019 13:39
09-30-2019 13:39
I tried troubleshooting also and couldn't find a solution. My Charge3 is going crazy. A few days ago there was a "glitch" at the top of the display. It looked like a strikethrough font. Then, last night it said the battery was low and as soon as I put it on the charger It had a white line through a black screen. It soon began vibrating erratically and the screen was flashing and changing. I've tried the resets. They didn't work. My app said it needed a firmware update, it didn't work. Now my phone won't even recognize the fitbit but it will vibrate when you pish the side button. The screen stays black and the little green light underneath hasn't lit up since I tried charging it last night. Everything was fine until I tried to charge it after everyday use. Just wondering if there is something else I could try. It's less than a year old. I wear it everyday and it's helped me so much that now I'm lost without it! Any help would be greatly appreciated. Thanks!
11-04-2019 10:20
11-04-2019 10:20
Hi,
I followed the steps to restart my FITBIT Charge 3 and it still won't turn on. I can feel the vibrations but nothing on the screen.
Can you please set me up with customer support
11-09-2019 17:51
11-09-2019 17:51
I have a Fitbit charger 3 and the screen is black. It was purchase 1 month ago and working fine until today.
i tried a reset but nothing is still showing up.
what else can I try?
11-09-2019 21:15
11-09-2019 21:15
12-11-2019 02:03
12-11-2019 02:03
I have followed the instructions to reset my Fitbit but it’s just flashing all the time. It is taking the charge but the time is out of sync. The smiley face appeared but is still flashing. I got the Fitbit for a present for my 70th birthday a year ago and have never been without it. Feels strange without it on!
12-11-2019 02:04
12-11-2019 02:04
Yes this is what I have done
12-17-2019 18:31
12-17-2019 18:31
Can I just throw it in the trash. This doesn't work.
12-18-2019 02:21
12-18-2019 02:21
Same thing happened to mine. I have had no reply either. It was bought as my 70th birthday present November last year. I have had three Fitbits and none of them have lasted longer than a year. Very disappointed as they are expensive.
12-18-2019 04:13 - edited 12-18-2019 04:15
Just so you know, the screen of my Fitbit 3 went black and after trying out everything I was told to reset it nothing work for mine.
i sent en email to Fitbit costumer service and they replaced it with a new one because it went bad just 3 months after I purchase it. It was still under warranty.
so if you had same problem in under a year you could get it replace from them too!
good luck!
01-13-2020 20:37
01-13-2020 20:37
Nope. Pressing and holding does nothing. The only thing more useless than my Charge 3 is this support forum. Your Windows 10 app is garbage. It couldn't sync even if it was the freaking Titanic.
01-22-2020 09:56
01-22-2020 09:56
This is crap. I'm on hold with customer service and was chatting live with someone. You guys dont give a crap about your customers or the issues they have. All you have to say is we are working on the issue! Will never buy from you guys again
01-22-2020 10:47
01-22-2020 10:47
01-22-2020 12:12
01-22-2020 12:12
I tried the two proposed solutions resetting and changing the clock face but nothing worked out, yet the app vibrates after 8 seconds but without a smile face.
01-30-2020 04:15
01-30-2020 04:15
Hello
i just purchased a Fitbit charge 3 today. I followed all the instructions to set it up and the screen only works when it is plugged in to charge. I have tried resetting, rebooting and restarting it as well as changing the clock face on the app. Nothing works and I am really disappointed.
01-30-2020 04:56
01-30-2020 04:56
I have tried literally everything and mine still isnt synching with my phone anymore 🙈🙈🙈
02-14-2020 09:02
02-14-2020 09:02
I have followed the steps multiple times
when i put the tracker in the charger it vibrates, so i know it is connecting
i hold the button for 8 seconds and it pulsates 3 times at the limit
then nothing happens
the tracker is capturing my activity, but the tracker display doesn't show turn on
suggestions please
