01-20-2017
10:55
10:13
01-20-2017
10:55
10:13
How do I record yoga and pilates on my charge 2, I am new to this.
Thanks.
01-20-2017 12:31
01-20-2017 12:31
Welcome to the Fitbit Community @ellyp65. It's great to have you here. You can press the side button of your Fitbit Charge 2 to reach the Shortcut Exercises section. When you are there, tap the screen of your tracker to switch between the different options. If Yoga or Pilates are not there please go to the online Dashboard > Settings > Devices. Scroll down until you see Edit Exercise Shortcuts. Once you've added the new exercises force sync by following @WendyB's instructions.
Hope to see you around more often.
01-20-2017 12:31
01-20-2017 12:31
01-20-2017 13:40
01-20-2017 13:40
01-22-2017 11:22
01-22-2017 11:22
I'm glad to have been of help @ellyp65.
On another note, you are welcome to participate in the Discussions board. I'm pretty sure you'll find interesting topics to discuss out there.
Nice work! Now, let's get back to stepping.
01-28-2017 06:29
01-28-2017 06:29
There is no Edit Exercise shortcuts on this app just preset exercises.
01-28-2017 07:44 - edited 01-28-2017 07:47
I was able to customize my activities with Run, Walk, Hike, Treadmill, and Pilates. Now those are the only ones that I scroll through on my Fitbit.
01-28-2017 08:48
01-28-2017 08:48
01-28-2017 09:17
01-28-2017 09:17
Go to fitbit.com, not the app. Log in to the online dashboard and from there you follow the above instructions and easily customize your fitbit settings. Good luck!
01-29-2017 12:36
01-29-2017 12:36
@Tgawin @sueincinci It's great to see that you've visited the Fitbit Community. You can edit the Shortcut Exercises from the app too. Please go to the Dashboard and tap your tracker, scroll down until you see Exercise Shortcuts. You will be able to select 7 shortcuts at maximum. If you have selected all of them already please swipe left on any shortcut to remove and have space for a new one. To add a shortcut just tap the + sign on the right side corner.
On another note, I would appreciate if you keep the Community courteous. Everyone here is free to share their problems and ask for help. Here is a link for the Fitbit Community Guidelines.
Catch you later.
01-29-2017 13:01
01-29-2017 13:01
02-04-2017 07:28
02-04-2017 07:28
08-05-2017 12:05
08-05-2017 12:05
Hi, I've spent ages today trying to add Pilates. This last post actually provided the answer.
I think it would be helpful if these instructions were included in the Charge2 manual (at the moment the manual just directs people to the website. Which itself doesn't give clear instrctions just talking about tracker tiles). I've only just got a Fitbit so am new to the terminology but I expected the manual and website to have clearer instructions. Particularly as users had asked this question in the community forum. Thank you.
08-05-2017 16:36
08-05-2017 16:36
@Pilates_ the instrictions in the solution above are nocely spelled out.
As for the manual i don't see much, but in help i see that this doc on multisport is listed on the first page of your trackers help site. Through this doc there is a link to customizing the multisport menu.
All of this i easily found through a search of the help docs.
08-19-2017 05:03
08-19-2017 05:03
Hi. I have the dashboard on my phone but can't see 'settings' or 'device'. Can you help please? Thanks
08-19-2017 12:47
08-19-2017 12:47
Hi, at bottom right of Fitbit dashboard, click on Account.
Then under the Devices heading, click on the words Charge 2.
Scroll down under General. Exercise shortcuts is the last entry.
You can remove/add other exercises by swiping existing entries to the left.
08-19-2017 19:29 - edited 02-17-2019 18:47
Duplicate
08-19-2017 19:30
08-19-2017 19:30
@ellyp65 Since there is an american version and a foreign version. If your having problems following @Pilates_ answer
just tap on the icon of your tracker found on the dashboard. This works on all versions of the dashboard. This will take you directly to your Charge 2 settings.
The rest is the same.
BTW if settings is not found in the bottom right, it will be found in the top right
08-20-2017 04:01
08-20-2017 04:01
Thank you. Very helpful.
12-01-2017 00:35
12-01-2017 00:35
I have had a similar problem and thank you for your post which has been more useful to me than previous advice!
12-08-2017 14:04
12-08-2017 14:04
This thread is about a year long, but I hope someone is still reading it and can help. I have set my Charge 2 so that it lists Marial Arts. But when actually doing tae kwon do, how to I set the Charge 2 so that it "knows" what I am doing and can track it?
