11-25-2018
12:14
18:22
11-25-2018
12:14
18:22
Hi, I bought a new charge to and replaced device on my account via the app however it added the new device but the old device still shows as set up and has not reverted back to set up mode . I want to set the old one up for my wife but can’t! Help to reset it??
11-25-2018 14:20
11-25-2018 14:20
it seems that maybe you havent removed the old device from your account.
you could try this to see if it helps:- in the app click on the card (top r/h corner) to view your account, select the device you wish to remove, scroll to the bottom of the page and select " remove this charge 2 "
i hope that works for you, good luck
Best Answer11-26-2018 08:07
11-26-2018 08:07
Hey @J10leigh, let me give you a warm welcome to the Community! As @soccersnaps suggested, you have to remove the old Charge 2 from your account, then it will be available for your wife to use it with her account. If she has questions about how to set it up, she can review this help article: How do I setup my Fitbit device?
Let me know how it goes!
Best Answer01-21-2019 13:46
01-21-2019 13:46
I received a new Versa for Christmas and my wife would like to use my old Charge 2. I went about it a bit backwards in that I deleted the Charge 2 from my app before going to the website (as I almost never go there). Now the Charge 2 no longer shows on my account, but it will not pair with my wife's phone as it has not reset. Tried to reset it, but it fails each time. About ready to use as a hammer because now both my wife and I have about had it.
Best Answer01-22-2019 06:41
01-22-2019 06:41
Hey @TKell2014, welcome aboard! So you already deleted your Charge 2 from your Fitbit account but still not connecting with your wife's account, right? Ok, let me suggest you something else, could you please also "forget your device" from your phone? The tell your wife to try to set it up the Charge 2 on her phone again. I'd like to also know, which phone model is you wife using, is it a compatible device with Fitbit trackers? Check that out on this link.
I'll be around!
Best Answer01-22-2019 07:42
01-22-2019 07:42
Best Answer01-22-2019 09:24
01-22-2019 09:24
Thanks for the update @TKell2014! Sounds great that she can now enjoy the Charge 2 and it's features with her phone. 🙂
If further questions come across, let me know!
