03-19-2018
08:50
18:54
03-19-2018
08:50
18:54
My question:
How can we see a total of just our active( exercise) calories for the whole day ? Is there a way to see just my burnt cals from exercise ? I have to go into each logged activity and add up manually to see how many cals have u burnt during exercise. Which is a tedious task. Some help would be appreciated.
03-19-2018 09:00
03-19-2018 09:00
Hi @atmansheth,
I think that's the only way, if you need to know only calories from exercise. Hopefully I'm wrong and someone will correct that.
If you go into the app and click the heart icon, you can view the heat rate data for the day. On that screen, it will tell you how many calories your burned for that day, by heart rate zone. So that will tell you how many calories you burned from cardio, but it wouldn't know if it was from elliptical or raking leaves, if that makes sense.
03-19-2018 09:05 - edited 03-19-2018 09:10
Another way, though still not simple, is to look at your calories burned graph for a time when you were not wearing device, to get the number Fitbit uses for your BMR per hour. Then multiply that by hours so far for the day, and subtract that from total calories burned.
Best Answer03-19-2018 09:09
03-19-2018 09:09
This helps to a certain extent, but I wish fitbit could include this one simple feature which could give us all the active cals separate from our BMR.
Thanks for your help though.
03-19-2018 09:12
03-19-2018 09:12
I think it's a good idea also.
@atmansheth, consider proposing it on this section of the site that Fitbit monitors:
03-19-2018 09:12
03-19-2018 09:12
And also, if you go into the HR graph it only shows me the time duration during that HR zone. Still no place for total cals burnt.
03-19-2018 09:14
12-09-2018 03:20
12-09-2018 03:20
Yes it's needfull
Best Answer04-12-2019 09:04
04-12-2019 09:04
I have been just starting the tracking for the treadmill option before I get out of bed and it will calculate just your active calories if you let it run continuously throughout the day!
Best Answer04-12-2019 09:15
04-12-2019 09:15
@tpich wrote:I have been just starting the tracking for the treadmill option before I get out of bed and it will calculate just your active calories if you let it run continuously throughout the day!
But that is including your BMR calories during the day too. Your base BMR calorie burn is going on all day also, as well as when in bed.
Best Answer04-12-2019 09:22
04-12-2019 09:22
Best Answer04-12-2019 09:47
04-12-2019 09:47
@tpich Did you check your calories burned just before you got out of bed and started the treadmill activity? I think you would have to know that to be sure the 500 calories are not including MBR.
I just tried a mini-test, started treadmill exercise, sat quietly for 5 minutes, then ended it. The exercise summary said I burned 8 calories in those 5 minutes. Looking at my overnight data, I burn 7-8 calories in 5 minutes asleep in BMR. That makes me thing those 8 calories I just burned in "treadmill" were actually my BMR.
Best Answer01-13-2021 15:42
01-13-2021 15:42
I know this is an older thread but it popped up when I googled a question! I have a Versa 3 and use the Fitbit app to view most stats instead of my watch. ( I find it easier to view on the larger screen) Another user had mentioned it but sure if the view is updated in the app since then. If you click your heart rate in the app, then click the graph for the day it will show you Exercise Zones with the minutes and calories burned from exercise. I believe this would be your total Active Calories.
Best Answer08-06-2022 13:22
08-06-2022 13:22
You can download a watch face for that. Hope that helps
